Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I see the motor co. uses them...Bee hive valve springs. My only experience was a new motor that came with them. broke one at 20,000 plus miles. Lucky me...no other damage. A very prominent top end expert in the East Bay Area (CA) suggested that I go back to the standard set up and gave me the number of a drop in set, which have been working fine. My question is: if they are all that, did I just get stung by chance, or is their failure rate higher?
I run a 100" motor and my pleasure is derived from travelling. !2,000 mile summers are not unusual. Yes...I sometimes travel fast.....lol
Reason: addition of vital info
We have used a ton of AV&V beehive(progressive wound)springs on top of even aggressive .650" lift cams, at rpms north of 6200 rpms.
Our Stage III, and Stage IV Heads feature them.
Have not seen a failure yet.
I suppose any spring can break, but the reason as to why would be the true culprit.
Scott
