Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
How bad is it if the Shoe, Sping and plunger are mixed up? I changed cam plates, and had to move the tensioners. Dropped the inner cam tensioner and it came apart. I think I put the spring in first, the plunger second, and then the shoe. Later in the evening I was going through my clymer 06-11 dyna service manual..page 159. It shows the plunger goes first, then the spring, then shoe.. If this is serious can I get the to inner tensioner without removing the pushrods/lifters? I used adjustables..but not the quick install. I had to remove the tank, remove rocker boxes, rockers. The bike is completely reassembled now, and I have started it. Any advice would be greatly appreciated.
Just to clarify, images of right (bottom)/wrong (top) assembly of a late model hydraulic tensioner are below.
Properly assembled, the spring sits atop the piston which provides a bit of a "cushion" as the chain rolls over the shoe. Improperly assembled, that cushioning affect is lost which would likely result in premature wear but that's JMHO. If it were mine, I would take it apart and assemble the tensioner properly. What adjustable pushrods did you use that required removal of the tank, etc. to install? You could buy a set of SE Tapered Quick install pushrods for about $135 from an online discount dealer like New Castle; cut your existing pushrods and save some time. It's a trade off manhours vs money; your call.
Lifters?? Nothing to do with R/R of the cam plate except that you need to hold them up to pull the cam plate and cams. We were talking pushrods; typo??
