Merch 120-131 ID
http://www.kentcountycustom.com/merch-products.html
Merch Motors
*Merch Inc.'s Fatso motors are built in house and are made up of an evolution bottom end (Crank Case, Flywheel) and a Twin Cam top end (cylinders, pistons and heads). The Merch Fatso is available from 100ci to 120ci and sizes in between. The Fatso motor fits Evolution, Shovelhead and Custom frames. Call for more details.
Kent County Custom Mfg. Inc.
Phone: (506)532-2033
Fax: (506)532-2036
Email: KCC@KentCountyCustom.com
But ................ 120" has a 4.25" bore and 4.25" stroke
.......................131" has a 4.25" bore and 4.625" stroke
Pull the timeing plug off and turn it over till you find some numbers on the flywheels ............... if you find them google the numbers and try and see what stroke you have! ................ seems I remember the middle part of the wheels with say 120 ............ 131 cast into them but I maybe wrong on that!????
