Engine knocking.
Old Jul 17, 2014 | 07:28 PM
Jchuk's Avatar
Jchuk
1st Gear
Default Engine knocking.
Hey boys and girls!
I have a recent problem of knocking coming from my engine. It's really hard to hear what part it's coming from but it sounds more like its coming from the right side around where the air filter or cylinders are. A day before it started, I pulled out and cleaned the carb and put it back perfectly and threw in a new set of plugs. It started to run beautifully after about an hour. Then that's when a knocking started. It doesn't happen at idle, or when it's sitting and I rev it. It only happens when I start out in first and second or if I'm going too slow in any gear. When I get up to speed the knocking goes away. I took it the the local HD shop and they said they would charge 1000 minimum to even start looking at it! Hahaha!! Are you ****ing joking?? So I said "see ya"! Can anybody shed any light or give me any tips or tests to try?
Thanks in advance!
Jase.
1990 Sportster XLH883
Old Jul 17, 2014 | 08:03 PM
hvacgaspiping's Avatar
hvacgaspiping
`Sounds like the compensator is starting to go.
Old Jul 18, 2014 | 10:21 PM
Jchuk's Avatar
Jchuk
1st Gear
I was thinking that but I don't hear it when I start it or when it's sitting still and rev it. I only hear it when I'm moving.
Old Jul 19, 2014 | 06:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
A compensator on a Sportster?
Remove the air filter and make sure the screws that hold the backing plate to the carburetor are still there.
Old Jul 27, 2014 | 12:30 AM
Jchuk's Avatar
Jchuk
1st Gear
Thanks for the reply, man. Yeah, everything is intact there.
Old Jul 27, 2014 | 11:19 AM
wurk_truk's Avatar
wurk_truk
What was the shop? You can PM me the shops name.
The reason I ask is this... it could be the compensator, it could be the clutch, it could be something to do with the rear chain/ drive belt (you don't dont the year or the model). Just because YOU don't wish to spend the money does NOT mean the money should be spent. The easiest way to glory is to have a shop with a dyno, so that the bike can be made to make the noise while sitting still. Our bikes... BTs or Sporties make al kind of noises that seem to come from point X, when in reality come from point Y.
PM me and I wil tell you a good shop up your was that has a dyno and would be someone I would trust.
Old Jun 26, 2017 | 08:58 PM
roussfam's Avatar
roussfam
Somebody is, welcome to the Forum
Granty
Jul 3, 2019 10:35 PM
Gamblir
Exhaust System Topics
May 4, 2013 08:42 PM
scaldwellk
May 5, 2012 12:24 PM
acebogey
Engine Mechanical Topics
Apr 17, 2012 01:51 PM
texfatboy
Jan 8, 2007 02:50 PM
