Engine Shut Off While on Interstate
Old Jul 25, 2014 | 05:07 AM
jackddg22's Avatar
jackddg22
Had the same thing happen to me. Bad connection on the neg battery terminal. 5 min fix. Need to have a good ground!!!
Old Jul 26, 2014 | 04:26 PM
ONEEYE05FLSTC's Avatar
ONEEYE05FLSTC
my softail did the same thing only it was me bending over to look at something and my helmet hit the run switch.
Old Jul 26, 2014 | 07:16 PM
0734's Avatar
0734
You can put me in the "I've done that stupid thing" crowd. I rarely ever turn off the engine kill-switch. We had our bikes shipped out west once and the truck driver had the bikes on the ground when the airplane landed with us. My bike would not crank...would not say a word and after some several minutes, I was in panic-mode. The driver saw the crowd around the bike trying to figure out what was wrong, came over and flipped the kill-switch, it fired up and the rest is history.
Old Jul 26, 2014 | 07:26 PM
Vincewd's Avatar
Vincewd
my 02 fat boy did it a few times and would start up after and then finely would not restart, it was the ignition switch, the grease they used got old and hard and made bad contact. I cleaned it and sanded the contact down and it worked until I got a new one keyed the same as the fork lock.
Old Aug 5, 2014 | 08:53 PM
monumaker's Avatar
monumaker
My guess is you bumped your kill switch.
Old Apr 8, 2015 | 10:24 PM
Mcdave's Avatar
Mcdave
Had a battery short out on my '06 SG mid-stroke doing 80 about 10 miles from a tiny town in MT. Just running along and the gauges started going full swing back and forth, 30 seconds later motor quit dead. Got pulled over and turned off key, then back on and everything looked good, hit start, needles peg, then dead. Long story short, shorted battery.
If it's 5yrs old replace it. Be sure to get a AGM battery. The vibration kills other batteries.( and Inner Fairing Supports) '06 Street Glides shake, a lot!
Old Apr 10, 2015 | 11:52 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Had the same intermittent problem and everything checked out fine. Replaced the ignition switch and never happened again...
Old Apr 14, 2015 | 10:51 PM
kkiley's Avatar
kkiley
If it came back on when you cycled the ignition switch, another issue could be the bank angle sensor. That was the issue with mine.
Old Apr 15, 2015 | 06:19 AM
98hotrodfatboy
Are you saying that these bike's now have a so called rollover kill switch?
LadyStreetGlide
General Topics/Tech Tips
Jul 3, 2016 06:20 PM
karim.samir
Dec 13, 2014 09:53 PM
1Deadman
Dec 9, 2014 11:20 AM
ronster2
May 20, 2014 09:46 AM
bstein1994
Sep 8, 2010 10:59 AM
