SE 260 cam
Old Aug 1, 2014 | 05:02 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The quicker the torque comes on, the more of it that is manufactured, and how long it carries into the upper rpm range is EXACTLY what a man can use for a street Harley.
The 48 in one cam that'll do just that, for a plug/play application.
That S&S cam is a ****-poor choice. Don't know who at S&S would suggest that at the OEM compression ratio..........
Scott
Old Aug 1, 2014 | 07:55 PM
DEDO1369's Avatar
DEDO1369
Jammie at S&S is the tech who recommended the HP 103
Old Aug 2, 2014 | 10:49 AM
cdonis's Avatar
cdonis
Bigger is not always bigger. They have a mr103 that might work better. I was about to order a set myself until I decided to buy a new home. Looks like cams are on hold. Although nobody on the forum seems to have much experience with the mr103 one indy in my area said he liked it a lot.
Old Aug 2, 2014 | 11:01 AM
qtrracer's Avatar
qtrracer
Bigger is always better, you want a rpm screamer right? Go big or go home, LOL
Old Aug 2, 2014 | 11:41 PM
Bearwolf's Avatar
Bearwolf
2nd Gear
Hell yes bigger is better...I wouldnt mess with a piddly cam that has less than .650 lift for a stop light racer..compression is overrated too.. 9.0 to 9.5 is all you will need to kick maximum *** with a .650 + cam. Make sure you get a go pro and video the red light race to prove it all!
Old Aug 3, 2014 | 12:39 AM
bklynbob's Avatar
bklynbob
What you want will cost $$$,a cam alone is not gonna cut it.....
Old Aug 3, 2014 | 07:42 AM
magnum629c's Avatar
magnum629c
I would go with what works great in your setup. The andrews 48 as hillside recommend is a great choice if not the best choice.. As far as bigger being better not so much I just had a friend build his bike with a woods 777 cam and talking **** and let me tell u he looked like a huge fool when my andrews 21 powered bike went flying by.. And he had a weight advantage.. That's a good feeling maybe he would have looked like less of a fool before he said I was stupid for picking a baby cam.. Whos stupid now
Old Aug 3, 2014 | 07:48 AM
magnum629c's Avatar
magnum629c
I have two other friends brothers and they have the same bikes there twin bikes setup the same.. They were fighting over cams one went with andrews 21 the other the bigger 37 the bikes are otherwise stock with just pipes.. The one brother was yelling go big or go home well he's not yelling that now as the big 37 cam he ran he said did nothing... He said his brothers bike with the small cam makes way more power...
Old Aug 3, 2014 | 09:36 AM
qtrracer's Avatar
qtrracer
Pffffft, 21 haha haha haha. Go huge baby, big cams and drag pipes and a huge tb, leave the rest alone. You will be the KING baby woo hoo!!!!!!!!!!!!!!
Old Aug 3, 2014 | 09:40 AM
JimGnitecki's Avatar
JimGnitecki
In selecting cams, I think there are at least two important things to remember that are often forgotten:
1. The more aggressive the cam, the more OTHER, matching changes are required in the engine in order for the cam to do its stuff (compression, head work, throttle body, etc)
2. For street versus track, even for occasional street RACING, it's the AREA UNDER THE CURVE that counts, because you are not always "going" at high rpm, but rather often coming to a dead stop and accelerating from that dead stop. Most drag races on the street are short, rarely getting past 70 or 80 mph, which means half the race or more is spent running up through the rpm range in 1st. If the engine doesn't make power below 3500 rpm, the opponent with the fat midrange engine versus high rpm engine will win.
Jim G
CarlFitzwater
General Topics/Tech Tips
Mar 12, 2018 05:53 PM
rdc401
Jan 25, 2011 09:22 PM
cncfxstb
Feb 4, 2009 03:34 PM
1931jamesw
EVO
Dec 18, 2008 10:40 AM
Deus Ex Machina
EVO
Jan 3, 2008 08:43 PM
