Level b heads
Old Jul 22, 2014 | 08:46 PM
wrenchguy24's Avatar
wrenchguy24
Default Level b heads
I just got my heads from fuel moto!!
My question the head gasket kit comes with the lower jug O ring
Do I need to pull the jugs and replace that oring???
cant find anything in the my manual that specifies replacing it if I just pull the heads!!
Old Jul 22, 2014 | 09:09 PM
kishstl's Avatar
kishstl
You do not need to replace O ring if you don't pull jugs. In fact, if I pulled jugs, I'd be replacing rings and re honing too(depending on mileage). But be careful when separating heads from jugs that the jugs don't pull away from the case. looks like you already replaced your stockers anyway.
Old Jul 22, 2014 | 09:14 PM
wrenchguy24
Thanks I really didn't think would need to!!
PS what kind of power does yours make with those heads???
Old Jul 22, 2014 | 09:21 PM
kishstl's Avatar
kishstl
Here is the dyno prior to the dragulas, it's a better flatter torque curve now with more low end.
traveler
Exhaust System Topics
Mar 25, 2020 10:04 PM
shovelheadjoe
Jun 21, 2014 01:40 PM
softail99custom
EVO
Jan 21, 2010 08:45 AM
FLTR2008TRIKE
Jun 5, 2009 10:00 PM
SEDELUXE
Aug 3, 2008 09:48 PM
