Engine sputters when switched off
Old Aug 10, 2014 | 09:11 PM
kris0082's Avatar
kris0082
Im not sure if its a stock carb or not, but I adjusted the screw that has a cord with a adjusting nut on the end that hangs on the left side of the carb. I thought it was called the idle adjustment screw please correct me if im wrong. I will check the throttle cable adjustments. Thank you for your help.
Old Aug 11, 2014 | 07:30 AM
0734's Avatar
0734
Showing my age....maybe. They started with the idle-adjustment cable thingy at some point in time. I had a Buell that employed the cable for idle adjustment, but the early CV's had a screw....as I recall.
In any event, you DO NOT set the idle screw to any particular setting. It's set to adjust the idle to the specified/desired idle RPM. The 3/4 out setting is for the idle mixture....the screw under the bowl. If you have a cable or a screw....doesn't matter. It does not have any effect on the mixture....only the amount of air allowed into the intake.
I think you've lost me a little here. The enrichener valve is on the left side of the bike and if you get that out of whack and get the valve lifted off it's seat....that will screw-up the mixture and you'll never get it to idle correctly.
I'm about out of suggestions here. I'd "take it" in if I were you.
theterribleone_vdc
Engine Mechanical Topics
Aug 19, 2016 07:39 AM
Chase1961
Jun 8, 2014 10:31 AM
joshoid
Jun 12, 2012 02:21 PM
D_B
Exhaust System Topics
Apr 19, 2012 07:05 PM
badchad
Sep 15, 2007 06:36 AM
