Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
5/16 (99-04) & 7mm (05-up) valves,beehive springs on the 7mm valves.raised int ports on `06 up.raised int with larger ex ports on `07 up.bolt patterns are the same on both
Would replacing the cylinder heads (Stock OEM Harley Davidson) on a 2005 FXD/I, with a later model cylinder head (06'-up) make a difference in performance?
What is the difference between the TC88 and TC96 cylinder heads (Ex:bolt pattern, valve, ect)?
If looking for more bolt-on power, the 96" head is not going to be a game-changer.
Once ported, both early and late will produce just about the same.
Scott
