Plugging the mid-shift hole in the inner primary?
Old Aug 11, 2015 | 07:11 PM
Scootertrash60's Avatar
Scootertrash60
Default Plugging the mid-shift hole in the inner primary?
Gonna install forward controls on my 85 Low rider and then ride it a bit to see how I like 'em.
What's the best way to plug the mid-shift shaft hole in the inner primary?
Old Aug 11, 2015 | 07:41 PM
apples402's Avatar
apples402
Not sure if it is the best way but mine has a bolt and washer through it bedded in black RTV. Was that way when I got it and still is, doesn't leak.
Old Aug 11, 2015 | 08:05 PM
br549A1's Avatar
br549A1
Read about this previously. Freeze plug of the right size is what you want. If I ever take my primary off again that's what's going on mine
Old Aug 11, 2015 | 09:43 PM
Scootertrash60
Ooooo! I like that idea!
Are we talking one of those rubber expansion plugs or the plain old steel frost plug?
I do have a NOS Wide Glide inner primary, but I don't want to put it on until I've decided on how I'm going to finish the primary case.
Old Aug 12, 2015 | 06:55 AM
br549A1's Avatar
br549A1
Drive in. I think it's 13/16" but check that before you do it.
Old Aug 12, 2015 | 09:41 PM
Scootertrash60
I always check a hole for proper fit before I plug it.
Old Aug 15, 2015 | 10:04 AM
Dr.Lou's Avatar
Dr.Lou
What do you when you find your plug is too small?
Old Aug 16, 2015 | 12:30 PM
WP50's Avatar
WP50
Add Popsicle sticks maybe
WP
Old Aug 23, 2015 | 07:56 AM
Scootertrash60
side to side man, side to side.
Old Sep 16, 2015 | 05:11 AM
br549A1's Avatar
br549A1
Here you go. Did it last night it's a 13/16" cup style freeze plug. Dorman part number 555-013. Might call around first it wasn't easy to find and without the part number the parts counter guys might not have ever seen one. Should only need one.
Attached Thumbnails Plugging the mid-shift hole in the inner primary?-photo824.jpg   Plugging the mid-shift hole in the inner primary?-photo895.jpg   Plugging the mid-shift hole in the inner primary?-photo818.jpg   Plugging the mid-shift hole in the inner primary?-photo507.jpg
