Evo rear brake caliper; neutral switch
Old Jul 26, 2018 | 02:50 PM
daven9113's Avatar
daven9113
Default Evo rear brake caliper; neutral switch
Just a couple of maintenance items that do not get a lot of search results. Here are some pics that might help others who might run into this problem.
Bike: 1989 FLHTC
Inspect the rear brake caliper bracket when you have your rear wheel off for looseness of brake pads. The pads "hook" onto the bracket, and that area on the bracket gets worn down over the years. It can break off a piece on the bracket, and you lose a brake pad (inner) while riding down the road. Ask me how I know?
I had to rely on e-Bay to buy a used good bracket. You can see the bracket in my hand with broken off piece. Not enough material to allow the "hooks" of the pad to rest on. Got new EBC semi-sintered pads for the rear to see how they work.
​The little tip of the neutral switch broke off, so I will be replacing it. If you get the right angle, you can take off the switch with 5/8" open end wrench.
Bob_fxdb
Jan 12, 2020 06:49 AM
daven9113
Jul 18, 2018 11:55 AM
Housegoat
General Topics/Tech Tips
Mar 16, 2015 12:53 PM
C.J
Mar 21, 2014 03:29 PM
outlawrider
Wheels/Tires
Jul 17, 2009 10:08 PM
