replace HD radio
Old Sep 29, 2014 | 09:03 PM
falconbrother's Avatar
falconbrother
Default replace HD radio
My HD radio has become just that, just a radio. Which means that while riding out in the country and I can rarely find a radio station that's worth a flip. I want to stick a new stereo in that slot with a connector for MP3, which is pretty much every radio on the market right now.
Question, will any single din radio fit in the slot? Can I use the weather cover that's on the current radio to cover a new unit? Do I really need a marine, weather proof radio or can I use any car stereo?
Money is tight right now so, I'm hoping that I can run to Walmart and get something well under $100.00 bucks. I had a radio on a goldwing back in the day and it was a 40 watt and did quite nice. I suspect I can get quite a bit more wattage than that for well under 100 bucks. After the first of the year I will probably be able to spend more on a stereo. Good enough is good enough in my book. This bike is for riding, not showing. I mainly want FM and a plug for an MP3 patch cord. I don't need or want much else in a stereo.
Old Sep 29, 2014 | 09:17 PM
Rabbito's Avatar
Rabbito
I don't know what year you have. I had any 89 took the old radio out put a Sony in around 179 bucks. But pretty sure any din unit would work. I was able to use over. What I did for the wiring was looked at the schematic for your then the schematic for the radio splice in make It work. Might have to use a longer bolt to hold on the cross bracket. (Again this was 89) only down side is the controls on the handle bars won't work. Wasn't a problem for me. And you can find Amal flash drive to store music on it to play. I recommend to upgrade speaker well in the fairing too. Just my .02 cents
Mine wasn't a marine quality radio either.
Old Sep 29, 2014 | 10:46 PM
Tee&Vee's Avatar
Tee&Vee
Advanced auto parts has a decent radio for forty dollars. It ain't gonna be a glove like fit but it will work.
Old Sep 29, 2014 | 10:53 PM
Prot's Avatar
Prot
What year and model is your bike?
Have you thought about just using an MP3 player or even your cell phone with headphones?
Personally, I don't listen to music while riding because I am listening for approaching danger or for sounds of mechanical failure. Besides, my exhausts sounds pretty sweet.
Old Sep 30, 2014 | 06:20 AM
nyokie's Avatar
nyokie
Not sure year of your bike but i have a cassette deck in mine, just bought one of the cassette adapters that has the wire off it to plug into my phone. Remember that ****? Olden days!
Old Sep 30, 2014 | 08:24 AM
flhchaz's Avatar
flhchaz
I installed and mp3 amp on my bike and hooked it up to the fairing speakers with out a radio. The downside is that I have to use the volume control on the player. I installed it behind the fairing and just have the wire coming through the empty radio box and fairing bag (flht). You can get an inline volume control, but I didn't like the way it mounted to the handlebar.
Old Sep 30, 2014 | 03:08 PM
falconbrother
Sorry, I have a 1988 FLHTC. The speakers still sound quite good. The AM/FM works for the most part. The reception isn't great so out in the country I usually don't have any good choices. My wife has a 300 watt stereo on her bike that's AM/FM and MP3 on a thumb drive. That really works well with plenty of volume and it was under $100.00 bucks. But, I can't imagine any realistic way to make that work on my bike. I was looking at stereos at Wallyworld and I think I could get a great stereo and new speakers for a shade over $100.00 bucks. I'd like to get it all done before the 11th of October as I have a big ride that day and would enjoy the tunes.
Old Sep 30, 2014 | 03:25 PM
Dr.Hess's Avatar
Dr.Hess
Depending on your fairing, you may have to do some cutting of the metal plate or not. 86's have a metal plate that the old **** style radios fit into. I had to cut that out to fit in a regular single DIN radio. Dunno about 88's. But besides that, yeah, go for it.
Old Sep 30, 2014 | 05:02 PM
RLH3175's Avatar
RLH3175
That's what I would have said, it takes all of my attention just to ride.....
Old Sep 30, 2014 | 05:51 PM
machinehed's Avatar
machinehed
Ex. stereo installer from back in the day.
I still think the din opening is standardised and any din unit will fit .
If your looking to get by until a later time and reception is your only current problem with the original unit , i will suggest these procedures...
Check for a good ground at the antenna mount point as corrosion occurs there.
Check were the ant. cable connects to the back of the radio and look for corrosion .
Last check is to use a multimeter to test the ant. cabel for ground continuity , ant. to plug in continuity and short in cable.
If this helps you should have original reception .
