Bike is not starting (click)
Old Oct 22, 2014 | 11:13 AM
Rhino-1's Avatar
Rhino-1
may be a dumb question, but have you checked the stator plug? Sometimes the connector gets corroded a bit or loose and causes some issues.
Old Oct 22, 2014 | 08:05 PM
watindes's Avatar
watindes
Did some diagnostic work today. I am getting power to the wire going to the large post on the side of the starter motor from the solenoid when I push the starter button. I believe my starter motor is toast. I don't know how to replace it.
Old Oct 22, 2014 | 08:30 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You still haven`t told us how you determined the battery was good.
Did you have it load tested?
Just because it is new doesn`t mean it is good.
Get the battery load tested, an auto parts store will do it free.
Don`t be so quick to buy a new starter motor. You haven`t done any proper troubleshooting yet.
Once you know the battery is fully charged and functioning properly you can start troubleshooting with a voltmeter.
Old Oct 22, 2014 | 08:48 PM
watindes's Avatar
watindes
You have a point but if I apply 12v from a know good battery ( my buddies road king) directly to the side post on the starter, shouldn't it do something? Right now all I have is a clicking relay. I will check the battery tomorrow
Old Oct 24, 2014 | 05:25 PM
watindes's Avatar
watindes
Did a test on the battery, it is good no doubt. Had the starter bench tested and it was good, it was not under load. Had a burned spot on the armature but got that repaired.
Put it all together and nothing. I jumped the posts at my solenoid, nothing. I have no idea what's wrong unless the solenoid is messing everything up. It is not kicking out like it should.
Good battery, bench tested the starter it is ok. Solenoid???
Old Oct 24, 2014 | 07:54 PM
Dan89FLSTC's Avatar
Dan89FLSTC
You are going to have to take a systematic approach to this.
Something that has not been mentioned yet, make sure all the battery cables and connections are clean and secure.
Don`t forget to inspect the ground strap that connects to the transmission case.
First thing to do is find out what the cranking voltage is.
Remember that when using a multimeter, touch the probes to the posts, not the wires or the terminals on the wires.
The voltages you are recording are the voltages you see on the meter while cranking.
Touch positive probe to + battery post, negative probe to - post.
Press starter button, record cranking voltage. It should be at least 9.5, write it down.
Now test the starter relay circuits.
Positive probe to + post on battery.
Negative probe to small post on starter solenoid.
Press starter button, the voltage indicated on the meter is the voltage drop of that circuit, it should be less than .5volt.
Positive probe on + battery post, neg probe to terminal 85 on starter relay, press starter button, record voltage. It should be less than .5 volt.
You will need a helper to do these tests, unless you have 3 hands...
Let us know what the results are, more tests to follow...
Old Nov 6, 2014 | 06:18 PM
machinehed's Avatar
machinehed
Only thing left is the starter solenoid , start relay , start button , cable
connections.
If you have a manual , do the starter solenoid checks described.
Old Nov 6, 2014 | 06:47 PM
Beemervet's Avatar
Beemervet
connections.
I guess you missed his thread where he said the starting problem has been fixed.............
JohnK-NJ
Jul 5, 2020 10:32 PM
LDB187
Feb 21, 2017 06:52 PM
floowmatt69
Jun 3, 2012 11:31 AM
panheadmatman
EVO
23
Jan 12, 2011 04:17 PM
nickster883
Jul 23, 2008 03:04 PM
