Brass bushing
Old Nov 23, 2014 | 11:33 PM
cowboy 51's Avatar
cowboy 51
Default Brass bushing
Ok Life has been in my way working on my bike , found some time today to put the cam bushing in question is, is there a brass bushing that goes in the nose cone for the other end of the cam ,I need one , the one thats there is not doing well at all , might be ebola or some chit like that , but it looks to need replaceing
Old Nov 24, 2014 | 02:45 AM
Spanners39's Avatar
Spanners39
There is a bronze bush for the cam part #25581-70 bushing, gear cover.
Old Nov 24, 2014 | 07:34 AM
johnjzjz's Avatar
johnjzjz
only buy a harley one or the bushing will have to be sized to fit the cam
if that bushing really looks bad to you then other things are going on as well
Old Nov 24, 2014 | 08:11 AM
cowboy 51's Avatar
cowboy 51
thanks spanner for the PT # , John jz the can bushing in the case side cam apart ,I did find all the parts , I noticed on gear side of cam the end had had some burn marks from heat & looked the bushing on cam cover has some marks in it so better swap it out
Old Nov 24, 2014 | 09:15 AM
Lakerat's Avatar
Lakerat
My understanding is you will need this tool to size and align the bushing to your engine if you want to do it right.
http://jimsusa.com/tech/instructions/1000/1702-IS.PDF
Old Nov 24, 2014 | 10:37 AM
carlgrover's Avatar
carlgrover
stupid question: does the cam bushing need to be replaced if the inner cam bearing is replaced or only if the bushing is obviously worn?
carl
Old Nov 24, 2014 | 10:44 AM
D_gyver's Avatar
D_gyver
Old Nov 24, 2014 | 01:24 PM
Spanners39's Avatar
Spanners39
carl
Only if its worn.
Old Nov 25, 2014 | 10:09 PM
cowboy 51's Avatar
cowboy 51
Thank's D for the video , since I don't have a press or the other special tool I run it over to a Indy who does
Old Nov 26, 2014 | 04:38 AM
Dun Roamin's Avatar
Dun Roamin
How do these bushings cope with the kind of acid they use for stripping chrome?
I'm about to do so, as the chrome's flaking off under the nose, and thinking of leaving it alloy or powder coating it. Mentally I was prepared to replace it but if I can get away without doing so, I would.
I put a Shovel cam cover in and it bubbled up badly ... I think it was the oil feed pipe rather than the bushes but am not sure.
Thanks.
