Sparks plug question
Old Jan 11, 2015 | 04:46 PM
  #31
98hotrodfatboy's Avatar
98hotrodfatboy
By what I hear 50 psi is the requirement for a dyno run. Keeps the tire from expanding which can create inaccuracies between low and high rpm range.
Originally Posted by Schex3x
Pump that rear tire up hard when you put it back on the dyno.
Old Jan 12, 2015 | 07:33 AM
  #32
br549A1's Avatar
br549A1
I'd go to a different dyno. Aren't all the runs subject to how well the operator knows the equipment? Many years ago I had my cammed 86 gixxer dynod by a well know local guy that built these engines. He came up with 127hp. I knew my bike well and could tell he wasn't even giving it full throttle. Now ten minutes after the run he tried to sell me an 1127 complete and guaranteed it to have 150 at the wheel. I declined. I knew what the bike and engine were capable of and there was already nothing on the road that could touch it. Not saying you have this problem, but I would do a new dyno run at another shop before I did anything.
Old Jan 12, 2015 | 03:01 PM
  #33
johnjzjz's Avatar
johnjzjz
just to keep this on the same page as the real people who actually have done this ---- -- at the road race tracks to keep apples apples jap stuff / Italian and others like buells - race in a HP to the rear wheel classes, like 106 to the tire we were in in 1996, and at the end of a race the 4 top finishers were dyno spun before they left the track - the dyno was right at the exit in the infield if a bike posted more than the 106 it was disqualified and that is how the 4th bike in the span was used as he then posted a 3rd -- NO oNE was allowed to even touch the bike much less blow up the tires - in this case let air out
blowing up the tires is good for as much as another 10 to 12 percent of power /// gimmick
corrected / weather / altitude / like 400 feet below sea level at 55 degrees a PC modding is good for at least 20 percent more power to any sheet
we have a guy in my area who brags he has the bikes with the most power and no one can touch his motors hahahahahahahah really
he also knows how to give you what you think you want and need with a click of the board
dont believe what you your self has not done and tested with the correct equiptment its all about making money and a dyno is like having a license to steal
Old Jan 12, 2015 | 04:15 PM
  #34
98hotrodfatboy
Default But?
When a tire is blown up to different pressures say 30-50 psi, does that not increase the diameter as well? I can understand how it would change the final ratio of motor to rear wheel but how can it affect the HP rating? I do know that centrifugal force will create a larger tire especially when it is under inflated, sort of like a set of slicks but as the wheel rpm increases so does the diameter creating more speed.
Old Jan 12, 2015 | 04:23 PM
  #35
Schex's Avatar
Schex
don't think ratio, think drag
straping down a car too tight on a dyno will affect #'s
Old Jan 12, 2015 | 07:13 PM
  #36
machinehed's Avatar
machinehed
Default iridium plugs
Originally Posted by Spanners39
I am a professional cynic and tried the Iridiums expecting them to be ho-hum but on both my bikes (Evo and then TC) they did exactly what the hype said they would, so now that is all I use.....although it will be a very long time before I need to change plugs.
My gist :
Take a look at the electrode of an iridium plug and a standard NGK or whatever . You will see that the iridium electrode is not much bigger than a ball point pen . As we are all riding vintage bikes with vintage coil voltages , it follows that the tiny indestructable irridium electrode provides a very low resistance to the coil voltage and gives the best spark . Nuff said.?
Old Jan 12, 2015 | 09:24 PM
  #37
2manyhobbies75's Avatar
2manyhobbies75
Maybe you should try the whistle dick plugs... I mean whistle tip. Good for 15hp - U.S. Patent No. 5,610,470
Old Jan 12, 2015 | 09:37 PM
  #38
SeaZund's Avatar
SeaZund
I think we're on the verge of finding those elusive missing 3 hp's
Old Jan 12, 2015 | 09:42 PM
  #39
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That is some funny **** right there!!!!!!!!!!
Old Jan 13, 2015 | 06:15 AM
  #40
98hotrodfatboy
Default Ya Think?
When you find it let me know.. as long as it's bolt ons....
