If you're only going to ride it around locally, within reasonable range of home, you will be fine, as you can get rescued if it gives up the ghost, however if you fancy a long day in the saddle and want to be sure of getting back home........
Fair amount of work to change that belt just for maintenance. (You know the inner and outer primary need to come off to change the belt?) Depending on how many miles and how far from home you intended on going, I might leave well enough alone and deal with the wrenching on an as needed basis.
The belt on my low mileage '93 FLSTN (<14K) is original and appears to be in good shape from a visual inspection. Curious to know if anyone has a drive belt with this many birthdays and no issues or is it time for a change just due to the age?
My belt snapped 3 miles from Stealership. I had some wrenching done and was just leaving the workshop. Probably coincidence?
FWIW, I called HD of Victorville CA a while back, to ask at what mileage or age they recommend changing the belt. The Service dept. told me there life-span is pretty much indefinite. And that if there is no visible damage or issues, there's no point in changing it. I had 50k miles on the belt I was referring to. A friend of mine that's an HD service tech for the past 10 years says the same. But I also carry a belt repair link in my tool pouch, just in case.
