solid intake manifolds- anyone using?
Old Feb 5, 2015 | 09:09 PM
mkguitar's Avatar
mkguitar
Default solid intake manifolds- anyone using?
Just wondering how you guys are making out over time.
I put a solid Bartels intake on in 1990...seen S&S and Ramjett manifolds.
or are you doing ok with the "compliance fittings"
mike
Old Feb 6, 2015 | 07:38 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Got a picture?
I use an S&S manifold myself.
Old Feb 6, 2015 | 08:19 AM
JohnMB's Avatar
JohnMB
I have used the Ramjet manifolds in the past with the butterfly Keihn. It is a good manifold,sure beat the heck out of the compliance fittings,
johnjzjz's Avatar
johnjzjz
haha - trick question complaince mounts are a thing of the past - the solid mount works for a while then also leaks - its the reason harley went to the tapered rings - its called expansion - it works better then the other set up the rings
in theory the complaince rubber blocks should have worked but they did not - tryed all of that in the late 80s none of it was the real fix till the harley change to tapered rings
Old Feb 6, 2015 | 08:50 AM
panz4ever's Avatar
panz4ever
Swithed the carb out on my 88 FLSTC to a CV with the solid compliance mount. So far, so good.
Old Feb 6, 2015 | 09:33 AM
Ruggs59's Avatar
Ruggs59
I use J.E.T.(Johnson Engine Technology) not to be confused with RAM JETT
Old Feb 7, 2015 | 06:40 AM
2manyhobbies75's Avatar
2manyhobbies75
How does a solid intake manifold different from a stock manifold?
Old Feb 7, 2015 | 07:34 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Compliance fittings were last used by the factory in 1989. They would crack and leak, and they were expensive.
Old Feb 7, 2015 | 09:04 AM
johnjzjz's Avatar
johnjzjz
like many 2 stroke bikes that have a rubber manifold head to carb - but harley used 2 front and rear heads then a alloy manifold into that plus gaskets for the heads to complaince < they called the rubber part this -- plus 2 hose clamps and the 4 bolts - in the end it did work for a while and it did make S&S rich because everyone was blaiming the keihin carb so they could sell you a money maker super E
Old Feb 7, 2015 | 09:30 AM
2manyhobbies75
Thank you for the explanation! !!
