Transmission jerking ?
Old 03-11-2015, 09:29 PM
Big Dave's Avatar
Big Dave
Big Dave is offline
Received 1,013 Likes on 558 Posts
Default Transmission jerking ?
1998 RoadKing 5 speed FLHPI 40,000 miles
very hard to explain and it does not do it all the time ----When taking off from a stop as you let the clutch out and you are starting to move forward its like the transmission slips or rotates 1/2 a turn then grabs and goes and everything is fine its not clutch slipping its mechanical , i checked the rear belt thinking a couple teeth missing its fine but thats what it feels like . I've changed fluids and adjusted clutch but cant figure this one out
Thanks for any help
Dave
Old 03-12-2015, 06:01 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,939 Likes on 3,374 Posts
Default Got a manual.....
I've heard the front compensator gear could cause that. You might want to post in the Tech N mechanical forum under Primary/Transmission forum...
Old 03-12-2015, 10:01 AM
falconbrother's Avatar
falconbrother
falconbrother is offline
It's hard for me to imagine anything other than the clutch that would do that. If the compensator was jumping 180 degrees you would have major issues. I would suspect warped clutch plates..maybe..
Old 03-12-2015, 10:31 AM
glidein wide's Avatar
glidein wide
glidein wide is offline
I wonder if your clutch cable is hanging sometimes near full release. Lube it.
Old 03-12-2015, 11:54 AM
flhchaz's Avatar
flhchaz
flhchaz is offline
Received 1,286 Likes on 499 Posts
If it is the original clutch, you may want to pull the clutch disks and check the spring plate in the middle of the stack. They do come apart and cause all kinds of issues. I put in a new clutch pak with extra disk that eliminates the spring plate, it's much better.
Old 03-12-2015, 02:29 PM
Schex's Avatar
Schex
Schex is offline
Received 6,854 Likes on 1,778 Posts
Tranny Jerking? eww
Old 03-12-2015, 02:33 PM
Schex's Avatar
Schex
Schex is offline
May be a bent shift fork, and the gear dogs not fully engaging, and jumping to the next before fully engaged.
Old 03-12-2015, 02:38 PM
Big Trev's Avatar
Big Trev
Big Trev is offline
Have ya checked the primary chain adjustment??
Old 03-12-2015, 04:01 PM
HGM's Avatar
HGM
HGM is offline
Originally Posted by Schex3x
Tranny Jerking? eww
That was my first thought, I had to make sure it wasnt Spanners..
I'd be inclined to think the compensator could do it, though I'd expect it to be all the time.. Otherwise, possibly a broken tooth on the gear.. Odd for sure..
Old 03-12-2015, 05:49 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Broken tooth on the gear or splines in the final drive sprocket are bad would be my pick from what you have said....I would pull the primary off and check it over.
Quick Reply: Transmission jerking ?
