Early Softail Starter
Old Apr 6, 2015 | 06:55 PM
pococj's Avatar
pococj
Default Early Softail Starter
I have a 1987 FLST that had the solenoid hang up last year after doing a minor freshening, mostly lookee-me stuff. It fried the solenoid, burnt/melted the positive battery and solenoid-to-starter cables, caused a shorted cell in the battery, and toasted the starter.
When searching for another Hitachi-type starter I was less than pleased at the replacements available as many of them are Chinese and suspect quality. I ended up buying an All ***** 1.4KW starter that is more powerful than the stock unit, and is also shorter/more compact. I replaced the solenoid with my favorite - Accel - a Throttle X battery, and all new super flexible battery & starter cables.
The All ***** starter turns the stock 80 inch motor over very quickly! So far I am well satisfied. Also, if you are in the market for a high quality battery, but don't like the usual HD price, Throttle X units are top quality, meeting or surpassing the stock batteries, but at about 2/3 to 3/4 the price. They also offer free shipping, and the several units I have gotten from them made the Michigan-Texas trip in 2 days.
Pics are the All ***** vs the stock Hitachi and the All ***** installed. I had to rotate the All ***** for the terminal to clear the custom round oil tank/fittings. The starter has 3 positions it can be set to for whatever a stock/custom application might require. Also, the All ***** starter does not have an end cover, nor does it require an outboard bracket making for a cleaner installation.
Attached Thumbnails Early Softail Starter-5-10-13-14-all-balls-vs-hitachi.jpg   Early Softail Starter-8-10-14-14-starter-oil-drain-breather-line.jpg
Old Apr 6, 2015 | 07:16 PM
Dr.Hess's Avatar
Dr.Hess
I'm running this battery right now:
Amazon.com : YTX24HL-BS Scorpion 12v 350 CCA Sealed AGM Motorcycle Battery : Everything Else Amazon.com : YTX24HL-BS Scorpion 12v 350 CCA Sealed AGM Motorcycle Battery : Everything Else
For $75 and free shipping, I figured I couldn't go wrong. It works. My bike is a battery killing machine.
Old Apr 6, 2015 | 11:39 PM
Hebrew Battle Rifle's Avatar
Hebrew Battle Rifle
My early Softail factory installed starter is connected to the ride side of the transmission and requires no battery or silly noid.
cajun1957a
Shovelhead
Mar 22, 2017 07:53 AM
Gibler77
Sep 18, 2016 05:11 PM
mbierbac
Nov 2, 2012 09:41 PM
parichar
Oct 1, 2011 02:33 PM
84sugar
EVO
Mar 23, 2008 11:46 PM
