EVO Exhaust
Old Apr 25, 2007 | 08:55 PM
ANKRA's Avatar
ANKRA
Default RE: EVO Exhaust
ORIGINAL: LowriderFXRS
Python III exhaust is what I'm running on my '91 FXRS-Conv.
http://www.denniskirk.com/jsp/produc...0303&mmyId=
Yes Pyton OK, however, thus was absent to me better. What do you say if around Reinhard's boy, Supertrapp, Samson, dungeon, Hooker Exhaust Products goes? Please, every information is important to me because I already 15 Exhaust Products, however, has had from Europe and they are not for Harley.
Old Apr 25, 2007 | 09:01 PM
ANKRA's Avatar
ANKRA
ORIGINAL: Hackd
ORIGINAL: ANKRA
I like it. To me from look also is OK, however, oh V*H is ... there comes NO right Harley sounded. It is as well as by a pipe wind blows, thus metallically, no vague, not at all.
Okay.....That lost a bit in the 'translation', but I'm certain my Deutsche would be unreadable if I attempted it....If the sound isn't what you 'think' a Harley should sound like....Then attend a few rally's and see what other's are using.
I still believe that the Thunderheader is a good exhaust for an EVO...I'm running a pair of SuperTrapp slipons with 18 discs installed. But I will switch to a Thunderheader when I can no longer get factory exhaust parts for my 1993.
Thus is your conviction and thus is good. I have understood and also know that Thunderhaeder are good, has also belonged here. You also have a crossover exhaust arrangement if your bike in the picture sees. With creossover he is also differently sounded than with 2-1 or 2-2 exhaust arrangements. So I will also like a crossover one, however, sing very expensive.
Old Apr 25, 2007 | 10:00 PM
Hackd's Avatar
Hackd
Yes, I agree there is a unique sound to the systems without crossovers. Look into a 2 into 1 system there are others available. If you want to go 'old school' and run a set of duals (mufflers on each side), they are also available. Check JPCycles online.
I personally do not like the sound of straight pipes or drag pipes or whatever you want to call them. I like a nice throaty (but mellow) sound. Actually my old Triumph Bonneville had 'TT' pipes on it when I purchased it used...I swapped to a Hooker header/muffler system and really liked the way that British Twin sounded...Wish I still owned it...
Oh...And you've got a really nice looking bike...
Old Apr 26, 2007 | 12:35 AM
mimo's Avatar
mimo
ORIGINAL: ANKRA
I see to have that here all notion if around engine EVO goes. I ask You that to her to me with looks for an exhaust arrangement for my Fat bell-boy in 1992 help. I drive at time s*s E carburettor, Crane single ignition, Kuryakyn air filter and now have a V*H THUS exhaust arrangement. Please, what do become to her to me recommending?
Nice ride, better yet it is an EVO.
Regards from Mexico.
Mimo.
Old Apr 26, 2007 | 08:23 AM
Buddy WMC's Avatar
Buddy WMC
FWIW,
I spoke with Ralph at Andrews yesterday in regards to a cam upgrade for my 93 FXLR. As it turns out Ralph has a 93 too .
To my surprise, he recommended the EV27 over the EV3 or EV46. He runs an EV27, S&S Super E and a set of long Pythons.
He advised that I would be very pleased with the performance. I'm going to follow the experts advice and run what he runs. I ordered the cam, bearing and adjustable pushrods. The Pythons are next when I can find the right price. BTW, Ralph mentioned not to go over a 9.5 to 1 compression ratio with the EV 27 cam. Sounds like maybe a set of Screamin Eagle heads might do just that! Best of luck with you choice.
Old Apr 26, 2007 | 10:14 AM
ANKRA's Avatar
ANKRA
ORIGINAL: olstoney
FWIW,
Yes it is quite good however if you want to change only the cam, adjustable pushrods, and exhaust arrangement then it is not enough. The changes make only engine strong if you one more carburettor of HSR42-45 MIKUNI nihmst and bigger air filter, S*S E carburettor is too small, then you should still change ignition on Singl then becomes OK. Here in Europe and, above all, in Germany Mikuni HSR is 42/45 the carburettor and functions really. It is in such a way if you change something with engine and only 1-2 things then other problems because come itself with what does not remain well stood. If, then everything
Old May 2, 2007 | 09:18 PM
ANKRA's Avatar
ANKRA
I want to buy a Supertrapp 2-2 to crossover exhaust arrangement. It is a silencer so that which experience with Supertrapp comes on the right and more different on the left from rear Rad.haben here? I will buy others like Reinhard, Thunderheader ., however, in Germany is not legal it and Supertrapp I Can legalise.
Old May 2, 2007 | 10:18 PM
Hackd's Avatar
Hackd
I have the SuperTrapp slipon mufflers on my 93 EVO. I'm running them with 18 discs (possible 24) installed. It sounds good, has good power (with the other mods), and I'm happy them. Like I posted before...When I can no longer get 'factory' exhaust pipes...I'll switch to a 2 into 1 system...Probably a ThunderHeader.
Old May 3, 2007 | 09:48 AM
ANKRA's Avatar
ANKRA
ORIGINAL: Hackd
Thank you for the information. Here in Germany and Europe Supertrapp is asked very much. ThunderHeader I cannot have because is not legal. Can you not take up the sound?
Old May 3, 2007 | 02:14 PM
Liveevil's Avatar
Liveevil
I'm running the V&H ProPipe HS (2 into 1)...sounds good...plenty help in the power...
