Combination Speedometer and Tachometer Kit
Old May 3, 2015 | 09:22 PM
Rubens Lara's Avatar
Rubens Lara
Stage III
Default Combination Speedometer and Tachometer Kit
I need to replace the speedometer of my 1998 HARLEY DAVIDSON ROAD KING CLASSIC - FLHRCI. Does anyone can advice me on what device to buy? I would like to install the HARLEY DAVIDSON Combination Speedometer and Tachometer Kit but I´m not sure it fits on my bike. Thanks!
Old May 4, 2015 | 05:52 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The Haley catalog should be able to tell you if it will fit.
Which one were you thinking about?
Old May 4, 2015 | 04:17 PM
Rubens Lara
Stage III
I´m thinking about this one (Combination Speedometer and Tachometer Kit):
http://www.jpcycles.com/product/560-...=Criteo_Active
Old May 4, 2015 | 04:18 PM
Rubens Lara
Stage III
The problem is that I need one in KMPH (we don´t use MPH here in Brazil)
Old May 4, 2015 | 04:25 PM
flhchaz's Avatar
flhchaz
Contact the manufacturer directly. I have a 97 flht that has a kph speedometer with a clear mph sticker on the glass. Any manufacturer should be able to change the gauge face for you.
Old May 5, 2015 | 06:03 AM
Joe_G's Avatar
Joe_G
I have a similar tach speedo combo. While it looks good, the tach is so far out of your vision you have to look down and take your eyes off the road to see it. Not safe when running to redline. A tach that mounts on the handlebar or risers is more in your line of vision and much more useful in my opinion having had both.
Old May 5, 2015 | 08:55 PM
Speedbarge's Avatar
Speedbarge
My 98 FLHRCI has that same gauge on it. Looks pretty, but if you plan on looking at rpms all the time it's not a good choice. Tach is below sight line.
Old May 19, 2015 | 07:55 PM
nzbernie's Avatar
nzbernie
Default what about this combo
Hi i run this combo on my bike works fine
http://www.jpcycles.com/product/560-274
or if you want you could go Dakota digital
http://www.jpcycles.com/product/730-798
Old May 19, 2015 | 08:16 PM
im's Avatar
im
Your 1998 Road King Classic is a hard wired electronic speedometer with an LCD odometer.
Translation: it is not a plug and play speedometer and would require the separate purchase of a retrofit kit in order to make it a simple plug-in style speedometer.
It requires about 12 wires to be cut.
If your speedometer does not have the bleeding LCD odometer screen (dark odometer window stain) then just consider a simple sticker on the outside of the glass with KPH printed.
The stickers are available on e b a y or you can have a printer make one for you.
Most will agree that an odometer on the tank looks cool but is rarely viewed due to position.
dukester
Dec 21, 2019 07:22 PM
belsebub36
Blowers/Turbos/Nitrous Oxide
Apr 22, 2012 11:38 AM
jgreg65
Mar 15, 2010 05:56 PM
b5mac
Jan 7, 2008 08:47 AM
