First Gear went Bye-Bye
Old May 10, 2015 | 12:18 AM
Thingfish's Avatar
Thingfish
Default First Gear went Bye-Bye
Ridding home on my '92 FXR and heard a loud clunk while downshifting. First gear won't engage. Shifter goes down, but it's not finding anything. Second and up seems to be where they used to be...
Not sure what it is. I limped it home a few blocks. Any guesses what I'll find? How bad and how much $$? I'm not knowledgable about transmissions, but it's only got 27,000 miles so I'm scratching my head. Assuming it's a stupid risk to try to ride it to the dealer?
Old May 10, 2015 | 12:33 AM
Ape_Hanger's Avatar
Ape_Hanger
That really sucks, hopefully it's something cheap, quick, and easy. I wish I could help, I'm here for moral support though.
Old May 10, 2015 | 12:45 AM
RidemyEVO's Avatar
RidemyEVO
Could be something as bad as a broken tooth on a gear or even the spring on shifter arm inside the tranny could be broke. Either way not the end of the world. It's really not that expensive of a job if you do it to yourself.
Old May 10, 2015 | 01:03 AM
Thingfish's Avatar
Thingfish
Thanks for the Support Ape.
Ride, shift arm spring is my first guess as that arm seems loose now. It was converted from mid to forward controls by the previous owner so non-factory mod is going to be the likeliest culprit. Any reason why it would only effect first gear if that is the case? Never touched a trans before...not sure I'm brave enough yet. On the other hand it doesn't sound likely catastrophic enough to justify a Baker 6 speed in the family budget... Good news/bad news....
Old May 10, 2015 | 06:01 AM
grbrown's Avatar
grbrown
I've had that lever return spring break. As I recall the symptom is that having selected a gear the lever stays where you pressed it. You should be able to lift (or press) the lever to find the normal position it rests in, then when changing to the next gear repeat. I actually rode mine for many months before fixing it, double-shuffling with my twinkle toes for every shift! The spring itself costs a few bucks, but costs a few hundred in labour to install!
If on the other hand you cannot find first gear by any means that doesn't sound so good.
Old May 10, 2015 | 07:21 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
From what I've been hearing they really aren't all that hard.
You'll just need some special tools.
If you really don't want to do it yourself I suggest you pull the tranny and take it to the shop to save yourself some money.
At least take the top cover off and have a look.
If you need an excuse then tell your wife that I said the tranny was lunched and you need a new gearset....Then get the baker!!!
Old May 10, 2015 | 11:58 AM
Thingfish's Avatar
Thingfish
Thanks guys. It's nice to have a starting point to get my head into it.
That's a good doctor's note Texas! HA! Thanks.
Old May 10, 2015 | 12:48 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Don`t pull the transmission out of the bike.
Take a look at the easy simple stuff first, the linkage.
Make sure the shifter arm at the transmission is tight on the shaft, no looseness or wobble (this is a common problem, inspect closely).
To check the shifter drum and shift forks you will need to remove the top cover from the transmission, then unbolt the shift drum blocks and lift out the shift drum.
You will be able to see the shift forks at this point, look for any obvious damage or issues.
To remove the shift forks, first remove the chrome side cover on the transmission (the cover with the dipstick), then you can slide the shift fork rod out and the forks will be loose.
This is all easy straight forward stuff requiring no special tools.
Remember to cover the opening on the transmission once you have the top cover removed whenever you are not actually working inside that transmission, because if you drop a bolt on the other side of the garage, you know where it will go....
Old May 10, 2015 | 12:50 PM
FlamedFXR's Avatar
FlamedFXR
Sounds like the shifter pawl spring. When mine broke on the way back from Street Vibes the shifter would just stay hanging down. I made it home by shifting up with the back of my heel pulling it up. Lots of little parts got ground up but luckily no gear damage.
Old May 10, 2015 | 12:52 PM
RHillbilly's Avatar
RHillbilly
Its not that hard have to pull primary ,clutch ,drive sprocket then pull top off pull cover on trap door and all the gears come out on trap door takes some special tools but not that hard
