Have a chance to pick up a 94 FXR. Here's the pro and cons:
Pro's:
S&S 113 crate motor installed in 2001.
Pro One Chrome wheels, matching pulley
Chrome brake rotors
Chrome swingarm
Drag bars internally wired
All braided lines
Custom candy black ghost flame paint
3 corbin seats
Bub pipes
Chrome outer primary, starter, lower legs
Wide glide front end
New battery
Low miles on Avon tires
Cons:
Odometer doesn't work and hasn't for a long time. No way of really knowing how many miles are on the engine. Need new Speedo/Odometer combo.
Triple trees and lower legs need re chroming
Carb won't hold an idle (probably just needs a small adjustment)
No directionals.
Asking $7,500. Not sure if the juice is worth the squeeze on this one.
Agree with texas hill country - unless you want this style of significantly altered FXR. For example, the wide glide front end would not be a "pro" to many FXR enthusiasts who,like me, spent time and labor to restore one to OEM. For the $7,500, you could get an FXR about which you would know more of the history (odometer) and be able to modify exactly the way you want.
If you're looking for an FXR, $7500 will get you a near-pristine, unmolested example with quite a bit of cash left over. If you're looking for a bike that someone else has already hot-rodded, then maybe this one works.
Madison county fairgrounds hosted an AMCA national meet for years.Good friends,camping,beautiful country and old motorcycles can't beat that.
Oh,and NO CROWDS!
