Understanding Reversion
Old Jun 20, 2015 | 09:33 AM
1997bagger's Avatar
1997bagger
Default Understanding Reversion
Came across a good video while checking out S&S carb tuning, the video is targeting many areas of exhaust, drag pipes mods, exhaust reversion explained and showed in simple forms, it is worth 11 minutes of your time.
Little while back put a thread out on tuning a monster on how they like fuel in the rich 12.0 AFR range rather than the basic 13.2 but a monster also needs a large exhaust. Have ran into the large exhaust has the ability to pull air (reversion) back into the engine when moving and throttle closed causing AFR's to go into the lean 16.0 range and cause a spit out the carb when hitting the throttle quick after the condition described. So when you hear big engines and street manors, it is true about taking some patience to repair side effects of horsepower on the streets but can be done.
Old Jun 20, 2015 | 11:16 AM
Beemervet's Avatar
Beemervet
Exhaust 101 for dummies.
Thanks
Old Jun 20, 2015 | 12:08 PM
glidein wide's Avatar
glidein wide
Thanks
Isn't that why some people come on here ?
I will watch video later to see how dumb I am......
Old Jun 20, 2015 | 02:05 PM
Harleycruiser's Avatar
Harleycruiser
Here ya go, reversion 102.
Old Jun 20, 2015 | 03:27 PM
1997bagger's Avatar
1997bagger
Thanks
Ok, I'm a dummy that is intrigued on how exhaust reversion can affect AFR's when tuning with equipment, this also affects engines with junk TD's, junk 2-1's. drag pipes just happen to be used as a extreme example of reversion characteristics. Tuning exhaust is just as important as tuning a carb so another reason why watching how AFR is effected by changing restriction backed by electronic equipment can be useful to some, if a Dyno tuning god is watching this video then yes it would be for dummies, non of us on here are a tuning god and can learn any chance we get.
Lolly pop's and bolt installs have came across this board before, thought this would helpful to those trying to make exhaust work. Personally have made adjustments to Propipes with more and less restriction that can move a torque area up or down but also requires a fuel change along with the more or less restriction exhaust changes. My current 3" baffled exhaust in the large engine is effected by reversion because of it's design for horsepower, have had to make adjustments caused by the reversion, not convinced reversion characteristics during tuning is for dummies
Old Jun 20, 2015 | 04:15 PM
johnjzjz's Avatar
johnjzjz
the way the old timers had taught me you never blip the throttle - you roll it on and roll it off - never a quick snap on or off the gas
Old Jun 20, 2015 | 04:34 PM
Beemervet's Avatar
Beemervet
Hey, don't get me wrong, I thought that was a great video. They explained reversion so well even a dummy could understand.
You learn something new every day. I did.
Old Jun 20, 2015 | 06:00 PM
Harleycruiser
Originally Posted by 1997bagger
Ok, I'm a dummy that is intrigued on how exhaust reversion can affect AFR's when tuning with equipment, this also affects engines with junk TD's, junk 2-1's. drag pipes just happen to be used as a extreme example of reversiake eto make adjustments caused by the reversion, not convinced reversion characteristics during tuning is for dummies
We are not making fun of you or the video, reversion was a big topic several years ago, and is kind of like an oil thread:-)
No offence intended.
Old Jun 20, 2015 | 08:50 PM
1997bagger's Avatar
1997bagger
My bad, put so much energy into the complex art of tuning I didn't keep a open mind.
Old Jun 20, 2015 | 09:35 PM
Beemervet's Avatar
Beemervet
No problema, I am in awe of your knowledge.
