Does anyone have an assembly drawing for the front axle/wheel on a 93 fxsts. My shop manual is for my 91 fxsts, but after going through a Chrysler station wagon a number of years ago, I replaced the front end with the newer low fender style (1993?) front end.
Something just doesn't seem right on the threaded end of the axle, as if there should be a bushing around the thread and inside the rocker to eliminate any play in the axle.
Cheers
JR
Reason: move to different area
Thanks. I finally figured out that the washer/spacer on the right side does not go under the head of the axle, but instead goes between the rocker and the brake caliper mounting bracket. This would appear to be the same as the 1991 installation.
