Trailer
Old Jul 25, 2015 | 01:36 PM
Owtlaw's Avatar
Owtlaw
The right trailer makes life easier.
Old Jul 25, 2015 | 02:02 PM
Beemervet's Avatar
Beemervet
Oh look.......... a COWASAKI!
Old Jul 25, 2015 | 02:47 PM
WP50's Avatar
WP50
Real simple answer is a 8by10 trailer longer if inclosed. Have had two dressers on my trailer more than a few times. I would Not want it any smaller.
WP
Old Jul 25, 2015 | 05:13 PM
nyokie's Avatar
nyokie
I have a 5x9 Vnose and its just big enough for my bike alone
Old Jul 26, 2015 | 11:31 AM
Hackd's Avatar
Hackd
Really appreciate all the responses! Thanks to everyone!
Originally Posted by Beemervet
Yep, five feet is not enough. Two bikes rubbing against each other can get ugly.
Yeah. Don't want that
Originally Posted by Tee⋁14238922
What about one north and one south facing?
Thought about that, but it's a lot of steel for this old guy to push up a ramp.
Originally Posted by Prot
Remember, you have to be able to back them out without falling off the ramp or if you need to put your foot down while in the ramp, and your foot goes to the ground instead.
Here is a picture of my set up. I think a longer two axle trailer would be better for two touring bikes.
The model I'm looking at has a full width ramp, but that is a possibility. I've had my scary times on a 12" plank.. Agree a tandem axle enclosed would be perfect for moving bikes, just not so handy for moving bulk topsoil or mulch.
My dad has his bike and trailer for sale. Here is what his road King looks like in it.
Thanks. That was what I pictured.
Yep. Thanks for that.
Yeah. I've seen pics of the U-Haul 5x9 and it looks like the HD fills it up.
The non-bike moving needs are more pressing. And I don't own a big tow vehicle capable of pulling an enclosed trailer. I'm going to go with the 60" x 110" single axle (3500#). It will be open with 26" sides. I'll set it up with a single removable wheel chock in the center/front. And it'll be fine for moving one dead Harley off the pavement back to the garage if necessary. And will work better moving my zero-turn mower, push mower, and other 'stuff' around. Plus it will also see duty hauling bulk topsoil, mulch, and other trash.
Old Jul 26, 2015 | 11:39 AM
Prot's Avatar
Prot
What is your tow vehicle? Mine is the Jeep Wrangler in the picture, and they are known for not being a great tow vehicle, although the four door like I have is better than two doors and older Jeeps, mostly due to the longer wheel base.
Old Jul 26, 2015 | 11:51 AM
Hackd's Avatar
Hackd
2002 Chevy Blazer (S10 version) 2dr. Severely underpowered 4.3L V6. Something like 160-190 hp. I've pulled a tandem axle car hauler (with a 93 mustang on it) about 100 miles with it, and it's borderline dangerous. 2000-2500 pounds is probably all it should be pulling around.
My son has a good sized enclosed, single axle trailer that he uses to haul his Yamaha Rhino around in. But he has a 1/2 ton Chevy Silverado 4x4 with the 5.3L V8.
Old Jul 27, 2015 | 10:28 AM
DeputyLoud's Avatar
DeputyLoud
I'm thinking your short wheel base and old suspension may be adding to your hauling woes? I have a 2001 Jimmy, same platform but 4 door. I recently put on new all terrain tires and shocks all the way around. I did not skimp on the shocks, went with a midgrade, closer to oem specs. I recently had to get it set up to haul my 6x10 enclosed trailer and I was actually surprised how well it did pull it loaded up with the bike.
Old Jul 27, 2015 | 11:44 AM
Frostbite's Avatar
Frostbite
I was wondering from your OP if you were talking flatbed or enclosed. If you're doing flatbed, why not take some duct tape or chalk and draw out a 5x9 space on your driveway? Then you can space your bikes in it and decide if you're comfortable with it or not.
Old Jul 28, 2015 | 12:25 PM
Hackd's Avatar
Hackd
That would have been a good idea. It's an open trailer with 26" sides.
I don't have the space to store a 7-8 foot wide trailer or an enclosed one. And it needs to do multiple hauling tasks, which would make an enclosed one impractical.
I decided to have it custom built so that the interior is 61" x 110". Fold up steel gate/ramp. I'll do the flooring in 3/4 ACX plywood (I can get 5x10 sheets), and go 24" up the sides/front/rear with 1/2 ACX plywood. I'm looking for a decent wheel chock that is removable.
It's a compromise, but it will have to do. The frame should be done in a couple of weeks, then I'll do the wood. When it's done I'll post up a few pics with the FLHS in it (because this is an EVO forum....).
