So I'm getting ready early for my bikes 30th birthday party,(winter).Getting a parts list together so I have an idea on cost, ordering what I can from J&P CYCLE to utilize my gold member savings. I have some **** picked out,looking for recommended items, pros and cons,as this will be popping my cherry. My first V8 went great and I want the same outcome with this rebuild.
This is all I wrote down so far.....
Ev27 Andrew
Hastings rings
Ss quick push rods
Jim s wrist pin
That's it so far,wanted Jim's tappet but $100 each ????
What do you have now?
Stock motor, stage 1???
I hope you added a top end gasket set with your wish list.
Why the wrist pins and the adjustable pushrods?
Pins are cheap enough, don't want to leave any worn parts behind. Figured I would replace the push rods with adjustable incase I need to get in the bottom end in the future. I would hate to have to cut new stock rods in future.
That is a mighty expensive guess.
FWIW stock pushrods are way cheaper than the adjustable ones.
You are better off taking the top end off again IMO.
My vote is for a James Gasket set. Cometic is a distant second imho. You will get Nobody to agree with that but it has just been my experience with them. Better than moco for sure.
Tom
Tom
After using both I can tell you that there isn't much difference between them.
Was told the motor is untouched when purchased. All comments are being noted/weighed and appreciated, now certain gaskets should be metal ??? Base ? Head should be stock thickness ? I don't want to increase compression to the point of having to change everything else around. Plus it's enough to kick as it is.
