Does this look right?
Old Jul 28, 2015 | 10:34 AM
falconbrother's Avatar
falconbrother
Originally Posted by texashillcountry
The spacer is held in place by the shoulder of the axle not the lower leg.
I'm not a fan of how they do it in the video because if done in that method there is a chance you are pulling in the right leg instead of it being straight down.
For myself I prefer to use a screwdriver on the right side while fully torquing left side nut then I tighten the nuts on the right.
But that's just me.
X2 and such..
Old Jul 28, 2015 | 05:29 PM
Crashone's Avatar
Crashone
Well I guess I need to pull that wheel and get it right. Thanks for the advice and the photo.
Old Jul 28, 2015 | 06:59 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Man the only way you are gonna change that is get a different spacer.
Both of my bikes have that gap and have for a very long time.
As song as you aren't putting side pressure on your forks you are fine.
Old Jul 28, 2015 | 09:15 PM
Crashone's Avatar
Crashone
I went from lace rims to mag rims, the parts book looks like the same outer spacer for both rims. Am I missing something? Thanks for the help.
Old Jul 28, 2015 | 10:18 PM
Schex's Avatar
Schex
If your caliper is in the right position, don't worry about the gap.
Old Jul 29, 2015 | 06:15 AM
texashillcountry
Dirt don't hurt
Man forget about the gap it is unimportant!!!!!!!!!!!
This is important!!!
Old Jul 29, 2015 | 06:20 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Proper rotor alignment.
Old Jul 29, 2015 | 06:26 AM
texashillcountry
Dirt don't hurt
Exactly!!!!!!!!
If you have the rotors where you need them and no lateral pressure on the forks then everything is good!!!!!!!!!!!!!!
Old Jul 29, 2015 | 07:56 AM
Crashone's Avatar
Crashone
Default Does this look right?
I will abide by the directive. Thank you.
Old Jul 29, 2015 | 09:33 AM
texashillcountry
Dirt don't hurt
Would that be the Prime Directive??????????
