1998 Ultra wont start
Old Oct 1, 2015 | 06:45 AM
carlgrover's Avatar
carlgrover
When you turn the ignition switch to "on" you should hear the fuel pump winding up. If you turn it on and hear nothing, pull the seat off and look for the white in-line fuse there. That will be the fuel pump fuse. It may be blown. You could have a spare on your bike behind one of the side covers. They just pull off by hand.
The buzz you hear on the right side when you turn off the ignition switch is the throttle position sensor moving back in. That's normal.
Carl
Old Oct 1, 2015 | 07:37 AM
Plumbwader's Avatar
Plumbwader
Originally Posted by texashillcountry
I don't know if you've ever considered this but if you converted to a carb it would be much easier to diagnose and fix.
Just a thought.
Yes, this is definitely going to happen in the foreseeable future. Dont want to lose my cruise control but the trade off will be worth it i think.
Old Oct 1, 2015 | 07:38 AM
Plumbwader's Avatar
Plumbwader
Carl
Cool Ill go check it at lunch time. thanks
Old Oct 1, 2015 | 07:46 AM
Scrmnvtwins's Avatar
Scrmnvtwins
Try to disconnect the fuel line form the tank. It is a QD so pull on the collar like you do an air hose. Remove and note if it seems to have presure, replace and try to cycle the ignition. If it had pressure the pump will not cycle. If you lost some in the fuel line R&R you should hear the pump when you cycle the ignition switch.
Old Oct 1, 2015 | 08:26 AM
Bigfoot1's Avatar
Bigfoot1
Just went through the same on an 01. We removed the entire MM setup and went with an S&S VFI. Starts and runs awesome every time. Worth looking into. http://www.sscycle.com/product/VFI-M...it-p22990.html
Old Oct 1, 2015 | 09:27 AM
Beemervet's Avatar
Beemervet
You don't have to lose cruise when converting to carb.
Old Oct 1, 2015 | 09:42 AM
Plumbwader's Avatar
Plumbwader
is it plug and play? Does it replace the stock ECU?
Old Oct 1, 2015 | 09:43 AM
Plumbwader's Avatar
Plumbwader
What has to be done to keep the cruise control?
Old Oct 1, 2015 | 09:50 AM
Crashone's Avatar
Crashone
If you are not hearing the fuel pump prime when you first turn it on check the plug under the tank cover to see if it worked loose. Check all connections under there.
Old Oct 1, 2015 | 10:23 AM
Beemervet's Avatar
Beemervet
I just got a CV from a '98 that had the proper linkage, or there are adapter kits for S&S or Mikuni carbs.
