98 Evo Regulator problem?
Old Oct 14, 2015 | 07:56 AM
Yankee Dog's Avatar
Yankee Dog
Made in USA ?
Old Oct 16, 2015 | 01:12 PM
!11B_FXDWDG's Avatar
!11B_FXDWDG
Default Checking diodes on Regulator
Originally Posted by 0maha
How do you do that?
The theory behind the diodes is to prevent feedback voltage from the battery in the charging system. Voltage should only be allowed to flow to the battery from the regulator and not from the battery to the regulator.
To test the diodes you need a multimeter with a diode function. Remove battery for theses tests. Switch to the diode function on your multimeter. Place the positive lead of your multimeter on one of the terminals in the connector that comes off the regulator and plugs into the stator. Place negative lead on the + battery wire. The meter should read voltage. Reverse the meter leads on the wires and you should not read voltage.
Old Oct 16, 2015 | 01:15 PM
!11B_FXDWDG
Originally Posted by portlandron
You said you used a fire extinguisher on the battery fire.
If it was a Dry Chemical type you may have created a bigger problem for yourself.
The chemicals in a Dry Chemical extinguisher are very corrosive to electrical components/connections. I would recommend that you remove every bit of the chemical from any connections it may have got on or in. Best way would be to use high pressure air to blow it out. Then I would wash the connection with clean water and use high pressure air again to dry it out.
Thanks for the tip. I was well aware of the dry chemical fire extinguisher being corrosive to electrical components. I didn't have much else available at the time to prevent a complete fire from engulfing the whole bike. I cleaned all of the chemicals off in just the fashion you explained.
Old Oct 16, 2015 | 01:21 PM
!11B_FXDWDG
Ordered a regulator (HD part) and it should be here Monday. Going to fight the fight to get the battery replaced by the local store but will probably being buying a new battery soon. I'm having withdrawals from not riding, so I hope to have her up and running again soon.
Old Oct 16, 2015 | 01:29 PM
!11B_FXDWDG
Originally Posted by Yankee Dog
Made in USA ?
I'm guessing your asking about the battery and TBH I'm not sure where they are made. It's an Autocraft Li-on and I've been told they are manufactured by Johnson Controls. However I'm not certain where JC's Li-on batteries are manufactured.
Old Oct 16, 2015 | 01:45 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
It will say on it where it was made.
Old Oct 16, 2015 | 03:02 PM
astark's Avatar
astark
That battery is made in China and if I'm not mistaken has only a thirty or ninety day warranty.
The sticker says made in china on front right of battery in the Advance Auto picture of it. Advance Auto used to carry USA made darn good motorcycle batteries but no longer do.
Old Oct 17, 2015 | 08:09 AM
Hackd's Avatar
Hackd
Originally Posted by astark
I got a Big Crank battery at Battery Mart and my problem was solved, which sure sounds a lot like the problem you are having.
++++ On Battery Mart and Big Crank Batteries.
However, I must report that my last MoCo battery lasted 7.5 years. Actually it's still in so-so condition, just 'sounded' a bit tired cranking the EVO when the temp was 40 degrees or below. So I replaced it last fall with a Big Crank.
One of the problems I was having with batteries, was traced to the connection where the regulator plugs into the stator. An intermittent connection will cause battery issues. Before 'hacking' a fix, I was running batteries on borrowed time after two years use.
Old Oct 18, 2015 | 12:57 PM
Beltdriven's Avatar
Beltdriven
Default R and R grounding
Most guys are satisfied grounding the regulator and rectifier at the frame where the R and R is mounted and that is ok for some.The better way is to run a 12 gauge wire from r+r grounding screw terminal to the neg terminal at the battery for reliable performance using a bit of silicon grease at the connections to prevent corrosion.
Old Nov 8, 2015 | 11:05 AM
!11B_FXDWDG
Sorry guys for the long gap in responding and the long posts. I got the regulator in and installed it. Unfortunately it appears I have more problems on my hands. Hooked up the battery after checking all my connections and it seems at least the TSM is fried.
It started sizzling as soon as I turned the ignition switch on. I'm pretty sure the overvoltage spike from the failing regulator smoked the TSM as well as popping all the bulbs. I'm going back through and checking all electrical components.
So far it seems limited to the TSM. Pulled all the bulbs in the bike to prevent reading false grounds/shorts and went through every wire and connector in the harness. Shook the harness while testing to ground and continuity between wires. Found nothing grounded or shorted.
Ordered a badlands module to replace the TSM and moving on to getting the ol girl back on the road. I'll test her today without the TSM and see if I can get good results from the rest of the bike. At the very least this experience is informative and allowing me to make some upgrades along the way 😂
