Idle questions
Old Oct 18, 2015 | 11:20 AM
sn95bullitt's Avatar
sn95bullitt
Default Idle questions
Please for give me with this stupid question. I bought this Softail back in June and idk much about carbureted bikes. Bike has been running fine till latly. When I start the bike with choke to warm it up it runs fine but once I start pushing the choke **** down the rpm's drop to 500 and the bike dies. Shouldn't it be around 1k at idie warmed up? My fuel injected EG runs at 1k once warmed up. When I first start it its about 1200 then comes down to 1k in seconds.
Is this the idie screw? I'm not sure what carb this is. Thank you for the help.
<a href="http://s175.photobucket.com/user/redjft/media/Mobile%20Uploads/IMG_20151017_182855406_zpstrcxtogb.jpg.html" target="_blank"><img src="http://i175.photobucket.com/albums/w157/redjft/Mobile%20Uploads/IMG_20151017_182855406_zpstrcxtogb.jpg" border="0" alt=" photo IMG_20151017_182855406_zpstrcxtogb.jpg"/></a>
Old Oct 18, 2015 | 12:32 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
From what I can tell that is an S&S carb.
I think that is your fuel/air mixture screw.
A wider angle picture would help
If it is an S&S then try this
http://www.sscycle.com/tech-info/carb-quick-guide/
Old Oct 18, 2015 | 01:13 PM
sn95bullitt
Thank you. I pulled the air cleaner cover off and it says s&s
<a href="http://s175.photobucket.com/user/redjft/media/Mobile%20Uploads/IMG_20151018_110736474_HDR_zpsrxkjwn9z.jpg.html" target="_blank"><img src="http://i175.photobucket.com/albums/w157/redjft/Mobile%20Uploads/IMG_20151018_110736474_HDR_zpsrxkjwn9z.jpg" border="0" alt=" photo IMG_20151018_110736474_HDR_zpsrxkjwn9z.jpg"/></a>
Old Oct 18, 2015 | 02:57 PM
texashillcountry
Dirt don't hurt
FWIW it does take a while (a few miles) before the motor warms up and idles right.
On mine at least.
What are the specs on that bike?
I see you have an aftermarket motor do you know what it is?
Old Oct 18, 2015 | 03:10 PM
grbrown's Avatar
grbrown
Rocker covers also look like S&S, same as mine, the other side of the crankcase should confirm.
Old Oct 18, 2015 | 03:31 PM
WVICEMAN's Avatar
WVICEMAN
The screw with the almost Phillips look is the air fuel mixture screw (the one I you can see well in the picture) if you look slightly to the left below that screw is the idle screw. After the bike is warmed up say after a couple mile ride turn the screw clockwise to increase the idle. An S&S carb is sensitive so it doesn't take much of a turn to increase the idle so just tweak it a bit at a time until you get around 900 RPM's. An EVO with an S&S is always going to take a mile or two to warm up and come up to the idle you set so be patient when you first fire it up.
86glider
EVO
11
Oct 11, 2017 03:40 PM
Vmann
EVO
17
May 29, 2017 06:00 PM
sn95bullitt
Oct 22, 2015 12:59 PM
PyroPornStar
Exhaust System Topics
Apr 21, 2013 06:57 AM
45js45
Apr 20, 2012 12:46 AM
