fuel sending unit
Old Nov 3, 2015 | 12:37 PM
WVICEMAN's Avatar
WVICEMAN
Default fuel sending unit
My gas gauge on my 85 FLTC isn't working and I suspect it is the fuel sending unit in the tank. Where can I buy a new sending unit? I checked the stealership and they want over 350.00 for one which is crazy.
Old Nov 4, 2015 | 11:46 AM
larsfum's Avatar
larsfum
Google is your friend
http://www.tristarrradiator.com/Harl...0Davidson.html
Part number is 75037-84
Although I would try to see if you could rebuild the one you have first.
Old Nov 4, 2015 | 04:03 PM
WVICEMAN's Avatar
WVICEMAN
Thanks Larsfum, I looked on line and could not come up with nothing. I also found a used one for 60.00. I didn't know you could rebuild them.
Old Nov 5, 2015 | 08:29 AM
grbrown's Avatar
grbrown
They are pretty simple things, so remove yours and take a look at it to see if it can be persuaded to work again. It is easy to test outside the tank.
Old Nov 5, 2015 | 09:46 AM
Schex's Avatar
Schex
Before you remove the sender, remove the wire from the center of the sender, turn ignition on, the needle should be all the way to one side of the gauge, ground that wire you removed(not to the center stud), and the needle should swing all the way the other direction.
Most fuel gauges read empty when the sender wire is open, and full when grounded, but could be set up to read just the opposite , doesn't matter, as long as you get full range open and grounded.
If it passes this test, the gauge and wiring are likely ok and move on to the sender.
Old Nov 5, 2015 | 12:52 PM
WVICEMAN's Avatar
WVICEMAN
Thanks for all the help everyone.
AUspicious
Jul 16, 2014 08:25 AM
WVICEMAN
EVO
Jan 16, 2013 03:13 PM
Longhauler
Jul 9, 2007 08:50 PM
flstci05
Exhaust System Topics
Oct 8, 2005 06:27 PM
