Evo rear rim size.
Old Dec 14, 2015 | 07:03 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by Baja272
That is the tire size but the rim I want is a 16x3.5 I'm hoping I can put the right tire on that rim. There is no clearance at all between the belt and the tire so I know I can't go with a wider tire
You can do the 3.5 rear. That's what I have on mine. It's a custom rim. I also know on 98's you can do a 140 rear without changing anything and it should leave about an 1/8"from the stock 1 1/2" belt but if you widen the rim a 1/2" it will also widen the tire a little so the next thing you'll need to do is a sprocket spacer of 1/4" to be able to use the 140 tire. There is still enough movement on your drive pulley to be able to move the rear pulley to the left a little and still track on the drive pulley properly.
Old Dec 15, 2015 | 04:58 AM
Tom84FXST's Avatar
Tom84FXST
I don't think anyone makes a tire that will fit a 3.5" rim above19" inn diameter. You can however use a 3" rim and a 120 series tire will work, that's about the max...... Have not been able to find a130 or larger.
Recommended wheel size for a 120/70/21 is 3.00-3.75...130 and 140 are available.
http://hdwheels.com/Product.htm
Old Dec 15, 2015 | 06:02 AM
98hotrodfatboy
I totally disagree with that chart for a Fatboy. Stock is correct. However there is no way you can get a 21" rim on the front with a stock fender. I am running a 19x3 w/120/70/19 Metzeler and only have a 1/2" clearance to the fender. Also a 3" rim is doable for 120 series tire but if you go beyond that you would be pushing it.
Old Dec 15, 2015 | 08:56 AM
LQQK_OUT's Avatar
LQQK_OUT
The chart posted in the below link is for model year Fatboys 2000 - 2015. Since you don't have a signature on your profile, I'm assuming you have a model year 1998 Fatboy from your profile name.
Didn't Harley in model year 2000 on the Softails go to the Twin Cam 88B counter balanced engine with a different frame, along with a new rear suspension, one piece fuel tank, and better brakes? If so, isn't it than possible the chart is correct for a Fatboy?
Old Dec 15, 2015 | 10:32 AM
Uncle G.'s Avatar
Uncle G.
Keep in mind that mounting the same size tire on a wider than stock rim will bring the sidewalls further out. You say you have no clearance now, going to a wider than stock rim isn't going to improve the situation.
Old Dec 15, 2015 | 09:29 PM
98hotrodfatboy
Damn I missed that one. Sorry dude....
Old Dec 6, 2023 | 01:45 PM
Fishing4me2's Avatar
Fishing4me2
1st Gear
Hi, where can you find a custom rear rim for a 1998 softail custom that isnt spoke. Having trouble finding anything.
Old Dec 6, 2023 | 01:47 PM
Fishing4me2
1st Gear
Was gonna put this in the tire section but figured someone here would know. I have a 1998 springer softail and I want to get new rims. I know the front is a 21x2.15 and the back is a 16 but not sure how wide. The website with the rims I want have 16x3.5 and 16x5.5 so not sure what it would be. Thanks
where did u find the rear wheel for your softail
Old Dec 8, 2023 | 11:31 PM
98hotrodfatboy
Baja272 hasn't been on here in over 6 years.. Hears a company that I used... 3.5" will work fine.. 5.5" will not without swing arm modifications.
https://www.southernmachinewheels.com/
JAGlide
Jun 10, 2018 07:47 AM
fergml
Wheels/Tires
Feb 15, 2013 08:37 AM
burntcookie10
Jun 24, 2010 08:05 PM
WARG
Oct 20, 2009 07:04 AM
T_Rob666
Sep 20, 2007 11:59 AM
