1985 superglide electrical problem
Old May 8, 2007 | 12:20 PM
bobhdmcrider's Avatar
bobhdmcrider
6th Gear
Default 1985 superglide electrical problem
Anyone: I have a 1985 fxef (one of the 2400 built with chain drive, not a belt). A couple of days ago, I lost all of my turn signals and the brake light will not illuminate when I step on the rear brake lever,but the brake light does come on when I squeeze the front brake lever. Last summer, I replaced the rear brake , hydraulic pressure switch, so I don't thin that's the problem, plus when that went out last year, I still had turn signals. After checking all of the bulbs and replacing them , I then replaced the self resetting circuit breakers for lighting and accessories, but this did not rectify the situation.
Does anyone have any advice as how to pinpoint/correct this problem ?
Old May 8, 2007 | 07:43 PM
Shasta69's Avatar
Shasta69
Default RE: 1985 superglide electrical problem
Get a manual and double check the connection on your wiring block.
Wires do vibrate loose/off.
Got a voltmeter?....good... follow the schematics.
Keep us in the loop.
-P
Old May 8, 2007 | 08:16 PM
HD7585's Avatar
HD7585
If you have power on one side of the rear brake switch with the key on..................jump the two post with a jumper wire........and if your brake light works,,,,,,,,,It's the switch. I have a 85 Fxst and have been through 3 rear brake switches so far. For the signals I would try a new Flasher first
Old May 9, 2007 | 12:30 PM
bobhdmcrider
6th Gear
Would a defective flasher cause ALL of the turn signals to not come on al all?
Old May 9, 2007 | 12:32 PM
bobhdmcrider
6th Gear
Thanks-I've got a shop manual with a wiring diagram and will try to check the grounds etc.[hr]
Old May 9, 2007 | 07:43 PM
HD7585's Avatar
HD7585
YES
ORIGINAL: bobhdmcrider
Old May 11, 2007 | 04:51 PM
bobhdmcrider
6th Gear
I was able to identify and rectify the problems: the flasher unit was not working anf the rear brake lihht switch was also inoperative. I replaced both and the bike is now functioning properly
Pgh-mike
EVO
Jun 12, 2016 06:02 PM
choloman
Electrical/Lighting/Alarm
14
Jan 26, 2015 04:38 PM
dochawken
Jun 27, 2014 05:36 PM
shuggy
Nov 27, 2009 07:42 PM
gilmour68
Jul 13, 2009 06:48 PM
