Brake Light Problem
Old Jun 29, 2009 | 08:57 PM
gilmour68's Avatar
gilmour68
Angry Brake Light Problem
Well today has not been a good day...Got the news at work that I'm effected by a layoff effective Thursday. We have very few orders to fill in July and we're having on a "two week temporary" layoff that includes about 11 people.
Been with the company for 11 years and was the operations manager in March, now I'm a Quality Engineer making $7k less. After Wednesday, I might be finished there. We've had other temporary layoffs become permanent. But I digress... Sorry for venting.
Went out to the shed to work on some projects and get my mind off the recent developments. The neighbor stopped by to talk about the crotch rocket he just picked up. While we were BSing, I attempted to show him the HD brake light/turn signal mod on my '04 XLC.
Turned on the key and pressed the rear brake - nothing. Pulled the front lever - nothing. What the F?!!??!! The turn signals work and the taillight works, but none of the brake lights work.
So I took out the taillight bulb, both filaments are intact. I measured them with a meter and powered it up with a power supply. Both filaments are working.
I then pulled off the seat and removed the rear brake light/turn signal module to eliminate it as a problem. Still nothing. Pulled off the battery side cover and checked the fuses. Besides some oxidization (which I cleaned) they were all good.
What do you think could be causing this problem?? Is the relay in the fuse box part of the brake light circuit? I haven't had the time to do a forum search so I thought I'd just ask. It's got to be something common to both the front and rear brake systems.
Thanks in advance... Hope I can get this fixed quick. Now I have some time off and a chance to ride, but I don't want to ride without brake lights!!!
Old Jun 29, 2009 | 09:50 PM
RATROD HOG's Avatar
RATROD HOG
just a shot in the dark,but was the key the whole way on?
hell i dont no
and i'am in the same boat as you are with work right now,sorry to hear of this,yes it sucks
Old Jun 29, 2009 | 10:12 PM
gilmour68's Avatar
gilmour68
The key was fully on and I even started the bike once to try it. No brake lights. I was looking thru the Clymer manual and learned that the rear brake switch apparently controls both the front and rear brake lights. The front is somehow connected via a wire and the rear is run by hydraulic pressure.
The test is to remove the wires from the light and check for continuity when the rear brake pedal is depressed. I got a reading of 150 ohms, not exactly a good connection.
So I decided to short the terminals on the switch together with the key on to simulate a braking situation to see what would happen.
Sure enough the brake lights lit right up. Guess the friggin' rear brake switch went bad. Now I just have to see if the dealer has one in stock and hope it fixes the problem.
Old Jun 30, 2009 | 07:18 AM
RATROD HOG's Avatar
RATROD HOG
harley's been using that hi-tec switch for ever sure not like my old honda CB 750
Old Jun 30, 2009 | 08:20 AM
SportyPig's Avatar
SportyPig
I would check the connector where the brake light/tail light mod plugs in. I don't know if you did that install yourself, or not. There is a splice and pin connector modification that is required with that accessory. Sounds like something may have come loose there.
Old Jun 30, 2009 | 12:04 PM
Sundog's Avatar
Sundog
Check the front switch too. Make certain it is installed correctly.
Sympathetic regards on losing the job. Happened to me too. Nearly 10 years with the company and now done in August. Oh well! Just an "inconvenience".
Old Jun 30, 2009 | 01:01 PM
hottrocker's Avatar
hottrocker
Default Similar problem but maybe different. but solved
I took the tins off and sent them off to my bud who does painting. He did a great job. Looked great. Did a nice coating of antichip on the underside.
But when I wired up the rear fender and tested the lights....nothing.
No blinkers, no brake light.
Then it dawned on me. Harleys must be using the inside of the fender as a common ground.
Mine was all painted in really thick paint. Practically rubber coated on the inside. So I first shaved and then sanded the points where the bolts went in and contacted the frame. Vio'La!
So my point is that maybe you have a poor ground either due to rust or some other thing you may have done during your mod where your brake light housing bolts connect to the frame.
Old Jun 30, 2009 | 09:25 PM
gilmour68's Avatar
gilmour68
Turns out that both switches apparently went bad. I replaced the rear switch and the lights work only on the rear brake right now. I thought it was strange that both switches went at the same time, but it's possible that they didn't. One may have failed before the other, I just didn't know it.
Last week the lights were working based on what some co-workers told me. So apparently at least one switch was working properly at the time. It must have failed over the past few days.
Since I've been rear ended several times over the past few years, I think I'll do some basic safety checks before I leave home next time. I'm paranoid about traffic behind me (after being struck several times over the past year) and I tend to flash my brake lights (usually using the front lever) to alert drivers that I'm slowing. So I will be replacing the front switch soon.
In the meantime I'm back on the road and I guess I'll have to make sure I use the rear brake to signal the traffic following me.
Old Jun 30, 2009 | 09:31 PM
gilmour68's Avatar
gilmour68
Sporty Pig I did install the module myself and it had worked great up until now. I checked the module by removing it from the circuit when I first discovered the problem. The brake light still did not work. There was no splicing of any wires with this mod - it was a simple "plug and play", no soldering or crimping involved...Fortunately the switches are the problem and I'm back on the road again!!
Old Jun 30, 2009 | 09:49 PM
Filmy's Avatar
Filmy
I had some odd brake light issues recently as well. I found that my front brake (hand) lever only kicked the brake light on while the bike was running. Maybe it's an electrical power thing. Anyway, I replaced both switches and all works according to plan.
Just check your handbrake with the bike running before you buy another switch for it. They're a PITA to install without breaking something else.
