pistons
Old Jan 4, 2016 | 10:15 AM
  #161
IBDAGRIZ's Avatar
IBDAGRIZ
WOW!! Sixteen pages of posts on a cam swap and pistons. Don't ever ask about valve geometry then or we'll never see the end of it..
I use Indian Head Shellac on my base gaskets on my shovel and evo motors. No leaks.
Ever heard of the Hayden Oil Fix setup for cylinder base leaks? Eliminates that whole base gasket leaking issues as a rule. Never run 'em myself, as I have nothing in stock form they will work on, but have seen and installed them in others bikes.
Griz
Old Jan 4, 2016 | 11:47 AM
  #162
Big Member's Avatar
Big Member
If if wasn't for all the usual catfighting, it could have been 3. We've covered hand relieving pistons, have you considered reducing your base circle post-Xmas?
I was going to suggest Gide made two columns on a piece of paper or a spreadsheet, a) a "good enough" budget job, and b) classy "proper job".
Allow space on the side of the budget job for additional savings possible by canny acquisitions, and for the "proper" job to lengthen as budget and temptation allows.
This first half of both columns is going to be the same; gaskets, specialist services, and labor etc. Therefore, it's worth seeing, and comparing the differences before deciding which route to go. It's easy to be overwhelmed by all the options and opinions; end up just spending your way out of or into a hole or on things you don't need. It's good to be clear and specific about where you want to end up.
Will an average rider be able to tell the difference between the two ... sure. In the short and long term.
Strip, clean and measure. Know exactly where you are at to begin with.
So, distractionary tactics aside, where have we actually got to on this practically so far?
Old Jan 4, 2016 | 01:38 PM
  #163
WP50's Avatar
WP50
Originally Posted by johnjzjz
that chick was a cannabil you told me
Probably had more to do with what he was trying to feed her
WP
Old Jan 4, 2016 | 05:41 PM
  #164
glidein wide's Avatar
glidein wide
Enough crap about burgers !!!! I make the best anyway !!!!
What I took from this cluster f#%k of a thread. I can't hone and install new standard pistons because the rings won't seat. So that means I can't reuse my pistons ,cut OR not for valve clearance because the new rings won't seat with those either.... Which I never heard before that you can't pull good pistons out of a good cylinder, hone, rering,and slap them back in and be reliable, but what do I know....
I'm not collecting my parts from the Indy and buying the ev27 so I can measure this now. As it doesn't make sense any more. So it looks like a"must bore" if you want the rings to seat.
So,mid usa pistons .010" os, Hastings molly rings, bore cylinders, .045" head gaskets,27 cam...
Old Jan 4, 2016 | 05:45 PM
  #165
johnjzjz's Avatar
johnjzjz
Originally Posted by glidein wide
So John, should I put some ketchup and mustard on the James base gaskets when I get there or leave it dry ? You didn't clear up the post about you put something on your base gaskets......
i use Hylomar in a spray form -
i use 3 light coats and each has to dry then a wait a day or two for it to totally cure on both sides - we have a location specific for this in the shop ( no Dust
its the way it should be if you pick it up and it does not stick to your fingers
Old Jan 4, 2016 | 05:59 PM
  #166
johnjzjz's Avatar
johnjzjz
the reason is you dont want to hear spend money on WHAT you think is still OK
again - the 30 year old jug is no longer round all by its self - add to that you are changing the top and bottom platforms ( head and base gaskets )
evo jugs in my shop are torqued to steel plates then honed on a CK - 15 that mimics the rod / stroke ratio giving you the correct 60 degree cross hatch for a 1.87 rod stroke ratio
in the machine the cylinders after honing _ THEY are straight top to bottom - remove them from the torque palates and they NO LONGER are straight Because all evo jugs have a memory
the reason they are torqued in the first place in the machine CK - 15 as it copys the exact way the engine will be when it back together
Old Jan 4, 2016 | 06:40 PM
  #167
glidein wide
Thanks boss-man....
Old Jan 9, 2016 | 11:29 AM
  #168
glidein wide
So I just got back from the Indy, took my old pistons back. Thought I would post better pics of them for the curious ones,(originals)...also, the thinnest part of the piston top is .27"thick, someone was asking...
Old Jan 9, 2016 | 01:38 PM
  #169
johnjzjz's Avatar
johnjzjz
the location is not on the sides correction - it is but not the spot you think - the valve resessions are the deepest towards the inside top area of the oil ring actually, and those were never speced out for the cuts so it has no extra meat like the one we all use NOW - and its not an if it will be thick enough
BUT yours in your opinion will be fine or you would have dropped this long ago But you have not - hope it all works out for you - in the 2 weeks i am doing this i have never seen it happen but your convinced it will
Old Jan 9, 2016 | 02:09 PM
  #170
glidein wide
John, maybe you missed post# 164 ,I bought cast pistons, os,boring cylinders as you advised me to... Your buddy big Luke member was curious I think about the piston, I am not cutting these pistons up,I am keeping them because I am pack rat,only posted a clean pic for whoever wanted to see what they look like..... chill out with the crap post.
I don't have an opinion because I have nothing to base it on.... IT'S YOUR ADVICE I TOOK !!!
