Compensator woes
Old Jan 14, 2016 | 02:18 AM
stephtell's Avatar
stephtell
Default Compensator woes
Sorry for being thick BUT:
I've put together the primary drive for a testfitting.
First I've fitted the shim, then the two part sprocketassembly and on top of that the compensator.
Now when I turn the sprocket by hand it slides outwards as it should but the compensator can still turn freely?
Is that correct? Will it only grip when there's proper force applied as in: the engine turning over?
Bit confused me...
Old Jan 14, 2016 | 06:35 AM
grbrown's Avatar
grbrown
Wink
Take a look at this website and go to the 'belts, chains etc' page for your bike. Your sprocket should rotate freely on the shaft extension (before final assembly) and then be engaged by the sliding cam, which is locked to the crankshaft. Once the cover assembly is installed and the sleeve nut tightened, I wouldn't expect that anything will move if you try to twist it by hand.
Old Jan 14, 2016 | 08:43 AM
stephtell's Avatar
stephtell
Ah mr. Brown! What would I do without your kind help!
My assembly is correct per the site you mentioned BUT when I 'actuate' the sliding cam, it picks up the sprocket (as it should) untill it obviously blocks because I can't turn the crank by hand.
However, at that point I can still move the compensatorcover freely...
So I'm wondering if the actual force of the crank will push the cam outwards even more so that it will push against the cover and hence pick it up OR that something is amiss....?
Old Jan 14, 2016 | 04:31 PM
glidein wide's Avatar
glidein wide
It doesn't sound right to me,missing something there I think.
Old Jan 14, 2016 | 04:39 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Thanks GR, first 2016 part fish I have seen and all the way back to 41. Too cool.
Old Jan 14, 2016 | 05:07 PM
grbrown's Avatar
grbrown
Red face
However, at that point I can still move the compensator cover freely...
Aw shucks!
I can't help thinking that the cover should be clamped by that nut. We could do with one of our experts here!
I suspect something is amiss. The specified torque on that nut is pretty tight IIRC.
Old Jan 14, 2016 | 07:49 PM
Schex's Avatar
Schex
Bit confused me...
Assuming you torqued down the compensator nut,
something is wrong there, comp nut might be bottoming out on the output shaft, check and see if your model bike suppose to have a spacer behind the rotor, some do, some don't.
You can check the primary chain alignment per service manual, might give you an indication of what's going on.
They have thin shims to adjust the alignment to within .030", but it shouldn't be way off.
Old Jan 19, 2016 | 04:55 PM
glidein wide
Did you figure out what the problem was bud ?
jmd897
Engine Mechanical Topics
Feb 26, 2025 10:50 PM
HDSAE60
Mar 7, 2015 11:27 PM
trevorFXDXI
Aug 22, 2011 11:13 AM
Shag67
Jul 8, 2009 05:48 PM
Mullenix53
Exhaust System Topics
Mar 30, 2008 08:13 PM
