How to install cam 4* advanced?
Old May 9, 2017 | 07:33 AM
jmd897's Avatar
jmd897
Default How to install cam 4* advanced?
Can't find any youtube videos to see how its done? Looking at T-man 590 or S&S 585 and trying to move torque to the left a bit.
Old May 9, 2017 | 11:05 AM
Jamn's Avatar
Jamn
You need one of these from Andrews. Sprocket (+4 or -4 degree timing change) ............Part# 216323
Old May 9, 2017 | 07:38 PM
Jamn's Avatar
Jamn
When you pull the cam chest cover, you replace the stock cam sprocket with the +4/-4 sprocket. +4 side out for advance and -4 side out for retard.
Old Feb 24, 2025 | 05:52 PM
D Dot's Avatar
D Dot
I know this is a real old post but do I need to readjust the pushrods like installing a new cam or just replace gear?
Old Feb 24, 2025 | 07:46 PM
djl's Avatar
djl
If the new cam has a differnt base circle, pushrods might need to be adjusted. No on the gear.
Old Feb 24, 2025 | 08:52 PM
D Dot's Avatar
D Dot
I already have the cam installed and all I want to do is move the curve to the left for more torque down low. Was just hoping that it is just something done thru the gear change only. I will be getting it re dyno'd again as well.
Old Feb 24, 2025 | 10:11 PM
marcodarq's Avatar
marcodarq
Which cam do you actually have installed on what bike? You need to give us allmthecdata to help you. Your set up may not benefit at all from a cam timing change. Most of the time, the tman, doesnt need it and the 585 is a mid-high cam, so yourcset up may notmhave what it takes to benefit from the idea. Give us the rest of the info.
m
Old Feb 24, 2025 | 10:17 PM
D Dot's Avatar
D Dot
S+S 475 on a 114 CI RoadGlide Special M8. Lacks on the low end. It has gutted cat and KromeWerks slip ons with the ventilator AC
Old Feb 25, 2025 | 06:40 AM
rigidthumper's Avatar
rigidthumper
Spoon baffles will help that tremendously.
LINK
Old Feb 25, 2025 | 08:25 AM
bustert's Avatar
bustert
you already shot yourself in the foot with the exhaust.
yep you can shift the curve downward by about 500 rpm, BUT, will it be advantageous???
if you ride the lower rpm range, your machine will suffer. where it helps is in the mid rpm range where the engine starts to make power.
the leanest way is to change gearing. to effect the whole tranny, look at the engine sprocket.
you did not mention specifics on the machine but i would look at the johnson engineering twist gear to see if it will fit.
i run the sport gear and it is a real hoot. BTW: i run 4* adv because the engine was built for high speed.
build your engine for its intended purpose as a system, band-aid approach usually produces less stellar results.
