Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
compensating sprocket/sliding cam issue FXDX05
Old Aug 20, 2011 | 01:09 PM
trevorFXDXI's Avatar
trevorFXDXI
Stage II
Default compensating sprocket/sliding cam issue FXDX05
Had to replace my shifter pawl in my 2005 FXDXI. First 500 miles no problems. Soon after that, at idle, started to hear an occasional knock from the primary. Progressed to a more constant and louder knock. Drained primary to find dark oil and shavings. When removing drive components compensating sprocket nut was tight. I found wear on compensating sprocket and sliding cam. The only spot on the sprocket that looks worn is where the cam lobes sit closest to the sprocket. What did I do wrong?
Old Aug 22, 2011 | 11:13 AM
grbrown's Avatar
grbrown
Hi Trevor and welcome to HDF from the UK. While you have posted this in a good looking place, the hard truth is not many members of HDF call by here. You should get a better response if you post again in the Dyna forum. Best of luck sorting your bike out.
XTonerman
2014-2024 Touring Models
17
Sep 12, 2020 09:29 AM
32roadking
Apr 27, 2020 06:16 PM
jrplane
Sep 10, 2016 04:48 PM
ridefast91
Engine Mechanical Topics
Aug 3, 2014 05:28 PM
Mullenix53
Exhaust System Topics
Mar 30, 2008 08:13 PM
