Sparks plugs
Old Jan 23, 2016 | 01:33 AM
Gra490's Avatar
Gra490
Default Sparks plugs
I have put in Daytona electronic ignition on my 1985 Evo. What are the best plugs to run with these. Also what octane fuel is best. Currently use 95 or 98. Cheers
Old Jan 23, 2016 | 07:20 AM
bigpappa160's Avatar
bigpappa160
On the gas which I have a 91 Ultra Classic, I run the real gas non-ethenol, 98. It cost a little more but I can feel the difference and I actually get more mpg. Haven't checked it lately because I've been having the carb worked on for a recal and after that a fuel leak.
Old Jan 23, 2016 | 07:32 AM
glidein wide's Avatar
glidein wide
Octane I think is high enough, plugs.... well that's a matter of opinion and what you're bike prefers I say you can't get a better plug than a proven E3 PLUG what I run....
E3.34 is the number for your bike non-gapable..... pre-gapped...
Old Jan 23, 2016 | 08:58 AM
astark's Avatar
astark
Best plugs I have ever put in my 98 Fatboy are the NGK Iridium IX and I have tried plenty. I also just run the highest octane non ethanol premium I can find at the pump.
Old Jan 23, 2016 | 11:15 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I tried the E3's and I'm not impressed.
Went back to the NGK Iridium's (much better IMO).
Old Jan 23, 2016 | 12:42 PM
glidein wide
Old Jan 23, 2016 | 01:59 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I have also had very good luck with Autolite iridium's as well as NGK's. I guess as long as they are iridium's and not the copper tops.....
Old Jan 23, 2016 | 03:20 PM
Gra490's Avatar
Gra490
Thanks guys, I was considering the NGK iridium.Looks like that is the way to go. Thanks again
Old Jan 24, 2016 | 10:57 AM
astark's Avatar
astark
And just to add, I don't bother gapping my NGK Iridium plugs and just use as they come out of the package. They can be gapped and I have done so, but it can be challenging and I found no benefit after doing so.
Old Jan 24, 2016 | 12:44 PM
98hotrodfatboy
Just so you know, that the gap is truly based on the output of the coil...Always go what is recommended for you model...
