Yes Sir texashillcountry, it did it a couple of days before I took it in to get the carb recall done. Then after I picked the bike up I rode home on fairly straight roads so no sputtering or boging down. Noticed fuel leak when I went to start bike to go to work, shut it down trailered it in to HD shop. Got it fixed, driving it home, going up a hill started sputtering and bogging down until I got on a staight away. Don't know if the float is messed up or what, that's why I was going to take it out to some hills and see if it does it again, if so I'll get it fix
Ok so the sputtering happened before and after you had the recall done correct?
I'm beginning to suspect this isn't a carb issue.
Do you have the factory service manual for your bike?
Yes I have a service manual. This morning before work I looked under troubleshooting carb and fuel system. Didn't see anything about sputtering or bogging down
Suspected fuel problem- start from the top, like jzjz said, possible vent problem can be checked very easy, simply crack the cap loose and see if the problem persist,
If it does, remove the petcock and see if the screen is intact and clean.
If the fuel hose is old and deteriorating, replace it, then you get in and clean the carb.
Many people skip the source of the debris and just go straight in and clean the carb, only to have the problem repeat.
(just like replacing the needle and seat, only to have debris dislodge in the fuel hose and get caught in the needle and cause a overflow fuel leak)
Replace spark plugs with proper ones, that would be Champion RN12YC gaped .038 to .040.
Even though I agree with "could be fuel starvation", apparently you have already checked this, also along this line the fuel level in the bowl could be incorrect. (to low) If you think it could be this change level to "to High" (will now leak on the floor while shut down) and give it a test ride to duplicate the problem. Remember to measure the tab that shuts the fuel off on the float so it can be set back to original if this doesn't help.
OFF TOPIC sort of.
One question for everyone: Where in the hell do ya'll purchase your gasoline from, an old steel drum in the middle of a pasture somewhere? I've NEVER gotten contaminated fuel in anything when purchasing from a reliable source. No need to answer just wondering out loud.
245,000+ miles on wife's car, 367,000+ miles on MobyDick(White '90 Dodge Van), 98,000+ miles on '85 FXEF, and last but not least 127,000+ miles on Grape Ape '01 FXDXT and never a problem with contaminated fuel. Must be luckiest person on Earth. :-)
I would agree with all of this if his problem happened all the time but from what I can tell it only happens when going up hill.
Hell I would do all of the above just to rule it out but I don't think it will fix his problem.
Yea, that's actually just basic maintenance, after all, the screen is the fuel filter.
He never stated the fuel level in the tank, it could even be that the lower portion of the screen, above reserve, could be restricted.
And it could be related to load and demand, and not the uphill angle.
i had a similar problem with my 85, i ended up being the 15 amp ignition circuit breaker. i replaced everything in the ignition circuit and nothing fixed the bogging. i scoured the ignition schematic and noticed the only thing i didn't replace was the breaker. i changed that and the problem went away.
