Screamin Eagle Keihin butterfly carb. Anyone one know anything about them?
Old Feb 15, 2016 | 02:23 PM
Hebrew Battle Rifle's Avatar
Hebrew Battle Rifle
Originally Posted by tjhog
most folks that used that carb went to S&S and were not sorry ... ...
I am one of these folks.
Old Feb 15, 2016 | 02:31 PM
Racepres's Avatar
Racepres
At least it is American [the S&S] so good on that
Now lets really stir the ****, and throw in the new Mikuni while we're at it.
Wondering who will be the first to tell us what mikuni America means!!!!
Luckily I can make an old Ka-sneeze work or certainly a Bendix [American Made also] so I'll just say that I stand by My Favorites..But Don't throw the S&S away...I have had some extremely good Luck with S&S on the Drag Strip!!!!!
Old Feb 15, 2016 | 07:56 PM
Owtlaw's Avatar
Owtlaw
Originally Posted by texashillcountry
S&S E is way better than the CV IMO.
Well, your opinion sucks.
Old Feb 15, 2016 | 09:46 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
This coming from a man who can't turn off his turn signals!!!!
Old Feb 16, 2016 | 06:20 AM
flhchaz's Avatar
flhchaz
ouch!
Old Jul 27, 2017 | 11:25 AM
Delhispearman's Avatar
Delhispearman
I have to say that I have found this thread very useful since this week I looked past the air filter on my recently purchased '89 FLHS and found a Screamin' Eagle Keihin non CV carb. My bike also had what I believe to be the original H-D spark plugs still in it. It had only done 12000 miles and they were starting to break down after 28 years (!) and affect the running of the bike so I pulled them and replaced them with a pair of NGK BPR5ES-11 set at 0.9mm gap. This sorted the ignition issues I was having but after a run out I pulled them again and the the bad black colour that the originals had continues to indicate rich running. So the question is how to adjust this rich running. I should say that I have not yet inspected the air filter so if it is old/minging that might be the culprit but I would welcome any advice. I have a service manual but it is not helpful...Can anyone help?
Old Jul 27, 2017 | 11:59 AM
Dr.Hess's Avatar
Dr.Hess
If I recall, there is a standard low speed idle adjustment screw on top, and the main jet inside can be swapped out.
Start with a new air cleaner and I'd replace the compliance fittings before I went any further messing with the carb.
Old Jul 27, 2017 | 06:12 PM
Delhispearman
Thanks Doctor. Do we know how far to screw the mixture screw in/out?
Old Jul 27, 2017 | 07:24 PM
Dr.Hess's Avatar
Dr.Hess
I just happen to have the original MoCo Instructions for that carb sitting in front of me. Part number 91731-85A. Lessee:
Operation and Adjustment
Idle Mixture - The idle mixture screw is initially set at 5/8 turn outward from the full in position. Do not set idle speed or smoothness with this screw, it must be set within 1/8 turn of the 5/8 position. this screw adjustment has a great effect on the entire fuel curve.
It came with a 140 and 150 main jet. The part number for a 130 is 27106-85. Anyway, if you need other part numbers, I have them for the main, slow and power jets.
Old Aug 1, 2017 | 08:22 AM
Delhispearman
Thanks for this - I am now having trouble sourcing a replacement air filter for this - the type that fits straight on the throat of the carb using just one Jubilee Clamp. Anyone got a part number for this mushroom shaped K&N Cleaner?
