90 FLHTC forks
Old Mar 9, 2016 | 03:07 AM
OhioFatboy96's Avatar
OhioFatboy96
Default 90 FLHTC forks
I'm having my 90 FLHTC I just got gone through by my mechanic. He said my fork seals are leaking, he needs the service diagram for them. Can anyone help me out with this.
Old Mar 9, 2016 | 05:15 AM
grbrown's Avatar
grbrown
I'm not sure what he means by that! There are on-line parts websites like this one where he can see an exploded diagram and get part numbers for replacement parts.
Old Mar 9, 2016 | 06:25 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You need a better mechanic.
Fork seals are a very basic and common repair.
Plenty of youtube videos out there on it.
Old Mar 9, 2016 | 07:18 AM
texashillcountry
Dirt don't hurt
Another option is to go buy an Factory Service Manual.
That will give your mechanic all the information he could want about any part of your bike.
Old Mar 9, 2016 | 07:21 AM
Schex's Avatar
Schex
Also, the seals and bushings can be replaced without top cap removal or going into the fairing, cuts labor time by 2/3
Old Mar 9, 2016 | 07:28 AM
texashillcountry
Dirt don't hurt
Just out of curiosity what is your process for doing that?
Old Mar 9, 2016 | 07:54 AM
Schex's Avatar
Schex
Remove wheel, calipers and fender, remove the bolts at the bottom and the lowers will drop down out of the cowbells enough to get the clip out, grab the lower and slide hammer it till the seal and bushing comes out and releases the lower.
To assemble you need a pvc coupler split in two, use a hose clamp to hold it together to drive the bushing, spacer and seal in.
Only thing is that you don't have much stroke with the coupler when driving the bushing and seal in, but it works.
Lift the lower up and install bottom bolt, suck the oil in with a vacuum pump on the air ride with schrader valve removed.
Old Mar 9, 2016 | 09:26 AM
grbrown's Avatar
grbrown
Howard Messner has a couple of videos showing Amy stripping and rebuilding a set of touring forks, on his website, but unfortunately they seem to be disabled at present.
Old Mar 11, 2016 | 04:30 AM
OhioFatboy96
Thanks. I did purchase a service manual online download. It has what I think he is needing. Again thanks
Old Mar 11, 2016 | 06:39 AM
texashillcountry
Dirt don't hurt
FWIW the online downloads are pirated copies.
It may or may not work for you.
