Cam choice EV27 or VThunder 3010?
Old Mar 27, 2016 | 07:21 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by TPost
Holy crap!!! Thanks for convincing me I made the right decision to keep the stock pushrods. Todd
I put the stock ones back in mine when I rebuilt my motor.
I like them better than the adjustable ones.
Old Mar 27, 2016 | 08:52 PM
tmanbuckhunter's Avatar
tmanbuckhunter
Originally Posted by texashillcountry
I've had mine come loose but what happened to a friend is ridiculous!!!
Oh please, don't even post that bull **** acting like this is what the norm is. Tpost, the push rod that engine came out of is an evo on ****ing steroids with a slight dosage of satan. 89" stroker with a monster ****ing cam and tons of compression. Me and the owner of that bike that had the pushrod come apart like that aren't sure what happened, but it wasn't the pushrod that caused this. The plunger in the lifter actually undid it self and went sideways. Think of trying to stick a quarter right side up in a round hole. Bent the pushrod and blew out the tube. I have seen these broken parts in person and examined the lifter that failed. I think the pushrod slipped when the plunger flipped and went down into the lifter, and on the lift of the cam lobe it snapped the push rod and blew the tube. This was a LIFTER failure, not a push rod failure.
Old Mar 27, 2016 | 09:11 PM
texashillcountry
Dirt don't hurt
Please point out where I said it was the norm???????
Old Mar 27, 2016 | 09:17 PM
tmanbuckhunter
The point is that you're posting this passing it off as a pushrod failure when it's not. A stock pushrod probably would have bent and maybe even broken too. Not only that, the cams talked about here don't have nowhere near the lift or duration that the cam in that particular bike has. It's just not appropriate to post it like you did. If you didn't know, you didn't know. I don't know how much he informed you on what went wrong here.
Old Mar 27, 2016 | 09:24 PM
texashillcountry
Dirt don't hurt
I got that picture right after it happened and before he tore into it to find out what caused it.
All I knew was that the push-rod broke and came out the side of the tube.
That was the last I'd heard about it until tonight.
I still never said it was normal.
Old Mar 27, 2016 | 09:26 PM
tmanbuckhunter
Ok then, well either way, it's not something that happens... like, ever. First time I've ever seen it.
Old Mar 27, 2016 | 09:40 PM
texashillcountry
Dirt don't hurt
Thanks for posting what actually caused it btw.
Old Mar 27, 2016 | 09:56 PM
langwilliams's Avatar
langwilliams
I was hanging at the indy shop an an a bike was in that was down on power an it turns out a adjuster lock backed off an he just had to adjust it. I'd prefer solid stock ones but didn't want to pull anything else apart.
Old Mar 27, 2016 | 11:04 PM
tmanbuckhunter
NP, just my theory though. The plunger definitely came un-done so it only makes sense... in my mind anyways.
Old Mar 28, 2016 | 12:10 AM
daven9113's Avatar
daven9113
Dave,
The reason I'm keeping the stock pushrods is my rocker boxes need polishing BADLY and need to come off. Also, the non adjustables are a no brainer. I've heard of adjustables stables coming loose.
Todd
Todd,
Makes sense keeping the stock PRs, if you are taking the rocker boxes off. Because you are keeping your stock PRs, take extra time to ensure your o-rings are seated well for installation of PRs. It's always the top ones in the heads that could get pinched. If that happens, there are ways to fix without disassembly, but that's not going to happen to you right? LOL..
Dave
