Hard to Start
Old Apr 1, 2016 | 08:23 PM
RidemyEVO's Avatar
RidemyEVO
Texas on my old evo I think I had something around 165ish. I'm thinking I better recheck.
Old Apr 1, 2016 | 08:52 PM
RidemyEVO's Avatar
RidemyEVO
Just went out and rechecked and its the same as before. I tested the compression tester on my tc and its fine, checked it in the fall and it was 185 and still the same.
Any suggestions?
Old Apr 1, 2016 | 10:45 PM
RidemyEVO's Avatar
RidemyEVO
Took a bit but found the stock motor compression in a manual , 90psi.
Old Apr 1, 2016 | 10:58 PM
Schex's Avatar
Schex
Any suggestions?
Checking compression with the throttle wide open?
Old Apr 2, 2016 | 06:07 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Even stock my motor had way more than that.
I remember that much at least.
Old Apr 2, 2016 | 07:39 AM
Pothole914's Avatar
Pothole914
Originally Posted by daven9113
Nice bike.
Hard start on cold may be a jetting issue. If it starts OK warm, then that's where he should start looking. Does the bike run OK?
How do the plugs look?
Popping on deceleration can be 1) exhaust leak 2) too rich fuel mixture.
He used new gaskets putting on the exhaust correct? And there's no cracks in exhaust manifold.
Nothing wrong with checking the cheap stuff first. Good luck.
WRONG. Please don't give advise when you don't know what you're talking about.....
Old Apr 2, 2016 | 07:44 AM
Owtlaw's Avatar
Owtlaw
Yeah, 90 is the point below which you should rebuild, according to the Moco. A fresh motor is much higher. I can't help but think a motor with 90psi would seem pretty weak.
Old Apr 2, 2016 | 08:49 AM
98hotrodfatboy's Avatar
98hotrodfatboy
A stock Evo from the factory comes in at 8.7:1 static and with the N grind cam intake closing of 30* you will be left with a dynamic comp of 8.3:1 and a ccp of 165 psi.
135 psi is time to refresh...
Old Apr 2, 2016 | 09:50 AM
RidemyEVO's Avatar
RidemyEVO
Naturally
Old Apr 2, 2016 | 09:57 AM
RidemyEVO's Avatar
RidemyEVO
This motor doesn't have all that many miles on it since it had the Harley reman done on it. Basicly I bought it off the guy and put new tires and new exhaust and put it in the shed for two years and hand it over to my son when he graduated from hvac.
The guy was running wide open drag pipes on it when I brought it home, is it possible the drag pipes did in the top end?
I'm going to try another compression test today with a few squirts of oil down the cylinder, maybe its just rings, I hope.
