Starting issues
Old Apr 2, 2016 | 09:46 AM
glidein wide's Avatar
glidein wide
Originally Posted by grbrown
I still have my original '90 switch, when was the later one introduced? Could be worth getting one just because I now know about it!
Not sure how long they have been out, I bought mine two years ago thru J&P CYCLE.
Old Apr 2, 2016 | 02:56 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by 89flhs
tried restarting it and wouldn't fire up,
Did the starter crank the engine?
Did anything else electrical lose power?
Knowing exactly what lost power will determine which direction to take in troubleshooting.
Well I did find a broken wire 8n the dash,but I hooked up where it looks like it might have went and didn't make a difference.
Do yourself a favor, you have a 27 year old motorcycle: Get a factory service manual, don`t guess where wires go...
Old Apr 2, 2016 | 10:38 PM
98hotrodfatboy's Avatar
98hotrodfatboy
89 should have electronic ignition with a hall effect pickup in the nose cone. The factory setting for dead rev's on electronic ignition is 3 so it's possible that you didn't crank it long enough for the ignition module to send the 12 volt supply to the coil. Also these hall effect pickups can get hot and not send any signal at all till they cool. So it sounds like it in the pickup to me...
Old Apr 3, 2016 | 07:31 AM
glidein wide
This would be helpful information..... ayy???
Rkellogg
Shovelhead
Aug 12, 2017 08:31 PM
oil leak
Ironhead
Jun 4, 2011 03:35 PM
Seaweed1929
Dec 4, 2009 08:32 PM
JohnnyBravo
Oct 8, 2009 06:33 PM
jmpancoast
Oct 29, 2008 08:17 AM
