The voltage regulator or stator is my guess by looking at my wiring diagram, (the diode), or a bad switch. Besides that I don't see much there that could draw when turned off. Hot lead touching ground with frayed insulation?
You unhooked the batt now it won't draw through your test light. Maybe you moved the hot lead off of a short to ground, or you need to wiggle a bad switch? Idk.
I'd assume if the diode is bad (i guess it has one, idk), it's not going to reset itself by unhooking in the battery. If it's drawing backwards it's going to keep doing that. Least I would think so by what I know. And I don't know nothing
hey to everybody and thanks for the input,still tryin to chase it down, i tested the regulator by unpluggin it from its plug and putting test light to both terminals(one at a time) and the light didnt light, which led me to believe it isnt the reg(altho i had that happen before and replaced the reg). i'm thinkin maybe the solenoid as it is the only other part not wired to switch for power...?
Leave the regulator unplugged for a couple of days and see if the battery runs down. That would take the regulator and stator out of the circuit. Otherwise, you need a multimeter or simple amp gauge to diagnose it.
Touch one probe to negative battery post, the other probe to ground (frame, or the loose end of the cable you just disconnected).
If there is no amperage reading on the meter, it means there is no parasitic drain present.
If you do see an amperage reading on the meter, disconnect the voltage regulator (at the single wire at the battery or breaker), if this causes the reading to drop to zero, it means the regulator is the problem.
If disconnecting the regulator doesn`t change the reading, continue by disconnecting the breakers, one at a time (when you disconnect a breaker, leave it disconnected) until you find the circuit that is causing the parasitic drain on the battery.
If the meter still shows a draw, and all circuit breakers are disconnected, look for a problem in the wiring between the 15 amp breakers and the main breaker (ignition switch).
i did what you say...get a .02 draw which i figure is radio memory/clock...?
At this drain rate, for a 30AH rated battery, it would take 150 hours to run the battery down 10%. Assuming you read the current properly.
So, depending upon how long it takes for your battery to run down, and at what point you consider it run down....you might just have a bad battery.
Do, I'd suggest getting a full charge in the battery (12.7 volts). . Then disconnect both battery cables, and let the bike sit for the amount of time it normally takes for the battery to run down. If it runs down in this condition, then you need a new battery.
thats what im doin now, have battery disconnected and giving it the 5 days to see if it holds its start power...i had multi set on 10 amp and got that reading .02...so i took it from there that yes, it could just be a bad battery...let you know after monday,i try to start
