Cam install?
Old May 18, 2016 | 10:55 AM
BungoBill's Avatar
BungoBill
Originally Posted by glidein wide
Hey Bungo,did your top end get noisy after cam swap ?
Hi, I forgot about that.! Everything seems ok and I am just enjoying riding at the moment. Weather in Bonny Scotland a bit unpredictable this early in the year but I am hoping to put some miles in soon. Have just purchased a new OEM Rear Brake Rotor so heres hoping that the major spending is over. Nice to hear from you.i
Old May 18, 2016 | 11:18 AM
Prot's Avatar
Prot
Besides what has been said, do a compression and leak down test before you start.
Since it is a rev tech 88", try to find out what cam is in it already.
Old May 21, 2016 | 08:27 AM
Turret_plug's Avatar
Turret_plug
Stock cam is an EV-50
It's a strong motor, pretty punchy, I'm looking for some serious low end muscle, tired of everyone getting the drop on me when the light goes green. I know how to ride my bike...... I just want the front end in the air!
Old May 21, 2016 | 09:22 AM
Tommy C's Avatar
Tommy C
A Wood W6H would be a good cam for that 88in Revtech.
Old May 21, 2016 | 01:37 PM
Turret_plug
I thought that was a Twinkie cam?
Old May 21, 2016 | 02:06 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Nope that's an EVO cam.
You have to have high lift springs to use it though.
Old May 21, 2016 | 04:59 PM
Turret_plug
****! Im Looking for some simpler power!
Old May 21, 2016 | 05:19 PM
Tommy C's Avatar
Tommy C
I'm pretty sure the Revtech heads are already set up for high lift. Check your heads for travel & coil bind & find out.
Old May 21, 2016 | 06:51 PM
texashillcountry
Dirt don't hurt
There's an EV-51, EV-57 or an EV-59.
You got any idea which one you have?
Every one requires high-lift springs.
Old May 21, 2016 | 06:53 PM
texashillcountry
Dirt don't hurt
From what you've said you should have high-lift springs but I'd double check that to be sure.
Many here have recommended the W6 cam (uses stock springs).
