Cam install?
Old May 17, 2016 | 06:40 AM
Turret_plug's Avatar
Turret_plug
Are EVO cam installs difficult? I'm by no means a beginner mechanic, but I've never installed a camshaft before. I have plenty of tools, and will purchase cam install tools..... Just curious of the pitfalls associated. Recommendations are welcome, looking for some more low end punch in my 88" Revtech.
Old May 17, 2016 | 06:47 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
No.
IMO a blind drunk monkey could do it.
A couple of things to pay attention to-
1 End play of new cam
2 Make sure you put in a torrington bearing
3 There are 2 longer bolts in the cam chest, make sure they go back into the holes they come out of or it will leak
You do have the FSM right?
Old May 17, 2016 | 07:46 AM
TPost's Avatar
TPost
Originally Posted by texashillcountry
No.
That pretty much sums it up. Follow the factory manual and you can't go wrong.
Todd
Old May 17, 2016 | 07:49 AM
BungoBill's Avatar
BungoBill
Talking
No.
Hi texashillcountry, On your recommendation I went to the Stealership and asked for the FSM you mentioned. They say they have never seen or heard of a Fully Sober Monkey. sorry........couldnt resist it.!
Old May 17, 2016 | 08:00 AM
BungoBill's Avatar
BungoBill
Thumbs up
Hi Turret_Plug,I have recently (last year) finished an almost full
3 year + restoration on my 91 Ultra. I wrenched almost the complete resto by myself using the Factory Manual and receiving THOUSANDS of words of help and advice from Texas Hill Country and many,many others in this excellent Forum who kept me "going" with excellent tips and advice.
Bungo Bill (Scot/Brit)
Old May 17, 2016 | 08:38 AM
langwilliams's Avatar
langwilliams
I just went thru this....went well other than a dumb mistake I did...I didn't tighten down the ignition pickup cup an had a misfire.
Old May 17, 2016 | 09:19 AM
texashillcountry
Dirt don't hurt
Tell them to check the nearest zoo as I've never heard of zoo keepers giving alcohol to the animals.
Oh I forgot that you're a Brit.
Y'all are known to drive on the wrong side of the road and drink warm beer so I guess anything is possible!!!!
Old May 17, 2016 | 09:26 AM
BungoBill's Avatar
BungoBill
Meant to say......I upgraded the OEM Cam on my Ultra to a EV27.
I found a difference when going above 50mph on a Motorway/Freeway. The original Evo 1340 motor pulled EASILY and WITHOUT HESITATION to 90mph +. I cant say for sure if I noticed a great difference in the Perfomance from 0-50.mph and thats not what I was looking for but overall I have to admit I am WELL PLEASED with the EV27 Cams performance and the NEW TORRINGTON INNER BEARING. Bungo
Old May 17, 2016 | 07:05 PM
glidein wide's Avatar
glidein wide
Hey Bungo,did your top end get noisy after cam swap ?
Old May 17, 2016 | 08:10 PM
GraemeR's Avatar
GraemeR
Cam swaps are a piece of cake... You can even do it without having to remove the lifters, although the pushrods do need pulling (and I am assuming adjustable). Mind you if its your first then you do need to remove the lifter blocks to ensure that the Can end play is set up correctly.
Also its far easier to press the gear off the old cam and onto the new one - that way you do not have to worry about pinion gear sizing etc with the new cam.
yell out if you need help as I have swapped out my cam about 4 times over the years (Stock => EV35 => S&S Stock => EV31 => EV3)
