back tire
Old Jun 7, 2016 | 06:24 PM
98glider's Avatar
98glider
Default back tire
I installed a new back tire on my 98 glider. I noticed that it is not in the center of the fender. I checked the distance in the swing arm to the axle and is dood.. Any help ? Thanks
Old Jun 7, 2016 | 07:10 PM
Hackd's Avatar
Hackd
Don't know about the the gliders, but on my touring model, there are different size spacers that need to be put in on the correct sides.
Is your belt running true?
Old Jun 7, 2016 | 07:21 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That's normal.
Don't sweat it.
As long as your belt clearance is good and your caliper lines up on the rotor you're fine.
Old Jun 7, 2016 | 07:24 PM
89FLHTC's Avatar
89FLHTC
THC is correct. If the belt runs in the middle of the sprocket and the rear wheel is aligned properly, you are OK,. Check the belt while rotating the wheel forward. The belt will travel to the inside of the sprocket when the wheel is turned backwards (normal).
Old Jun 7, 2016 | 07:27 PM
98glider's Avatar
98glider
I had new bearings put in and the spacers are in there. The caliper is good and the belt is straight. Before I did this it wa okay. maybe when they put the bearngs in maybe they didn't push them in all tge way
Old Jun 7, 2016 | 07:40 PM
texashillcountry
Dirt don't hurt
Does the bike go straight when you let go of the handle bars?
If yes then quit worrying about it.
If no the find out why.
Old Jun 7, 2016 | 07:41 PM
flhchaz's Avatar
flhchaz
The tire is off center in the fender from the factory. Don't sweat it
Old Jun 7, 2016 | 07:47 PM
89FLHTC's Avatar
89FLHTC
How far off is it? Mines about 3/8".
huddy
Oct 5, 2022 05:04 PM
Turbols1
Jan 1, 2017 11:31 PM
Rdneck
Wheels/Tires
Mar 31, 2011 04:47 PM
kbrain
Feb 27, 2011 01:07 PM
rough rider
Sep 15, 2010 10:58 AM
